Kevin D Pem
RVF 1K Club
- Jul 29, 2020
- AZ
- Alpinelite
- 26'
- 2016 Ram 1500
- Yes
Question: Does this rig have coil springs? If it does I would not worry about sway. RAMs box frame and multi point suspension handles very well. Rims wider than factory actually cause suspension problems in the future, and can lead to unsafe conditions. Why because the vehicle geometry is changed for the worse. Stick with factory engineering for best results.Looking for advice. I have a 33’ TT, GVWR 9,400lbs. I’m searching for a truck capable of safely towing this TT. I’m considering a 2017 Ram 2500 Tradesman Crew Cab 4x4, 6.4L V8 Hemi, 6 speed Auto 66RFE Trans, 4.1 axle ratio. The Dodge charts give Max payload 3037lbs. Max Tow 15,837lbs. I know I need to look at door sticker for actual numbers. The truck has 14,500 miles. Dealer is asking $37,500. Any opinions?
More:
You are well within capacity of the truck. Somehow long seems to scare people. Maneuvering is the big issue for me. If the trailer has been built properly and you are properly loaded then have fun. you should be fine.
Equalizer hitch for that weight is best it keeps proper weight on steering wheels.
Problem I have with what you have said so far is, the weekend warrior statement. Safety comes when you can change your travel plans to accommodate weather. For instance: The popular weather forecast leads you to believe they can forecast 7 days out. Accurately they can forecast 3 days at best. that makes the 3 day weekend in question. As long as your plans are during a fairly docile month or season then no problems with a weekend joy ride.
The point is, For your use weather is key to a safe journey. The truck is capable, the trailer can be effected by wind.
