access to water control panel ?
Bareboy
I have leak behind the water control panel of my 2023 31F and am not sure how to get access to it to fix it. Any help is appreciated.
Bareboy, you would be better off going to the Jayco owners forum (they make Entegras) and all most or all of their C's are gussied up Jayco Greyhawks.
But, you can remove the four screws, two on each side, of the control panel to get partial access from the right side, pump side.
I have a very small leak also behind my panel where there is a 3 way plastic T-junction with Pex Tubing. I don't kneel very well now-a-days, and I don't have Pex Tubing tools, do I buttoned up the panel and will address it next season.
If its a pex connection, most likely the leak is where the put a piece of that flexible tubing made for beer taps and soda machines and is not designed to be clamped with pex SS rings. We had some rings that were undersized but mainly, I just double clamped it with regular ring clamps. The kind you use a nut driver on.
A photo would have helped. I did a google and what I found was this. Does this look like it's yours. If it is, good luck. The space is so limited. I think you would have to be a contortionist to access anything. Mine is similar. I tried to replace some of the pex clamps but gave up. I had my dealer fix it . The cost was minimal compared to the damage my body would have endured dealing with it.
