Do you know if someone winterized your rig before you bought it? You usually only see those valves changed when someone has winterized the rig.Thanks to the NEWMAR group on Facebook, I learned there is 3 valves behind the hot water tank.
The top and bottom must be open.
The one that is in the line that connects the cold and hot water, must be off.
Maybe. All the tanks were drained ant drain valves openDo you know if someone winterized your rig before you bought it? You usually only see those valves changed when someone has winterized the rig.
