Tyron Run Flat
Jim
North Carolina
Essex 4543
2016 Jeep Rubicon
Tyron Run Flat
Anyone use these? I had never heard of them before, albeit my RV'ing background is limited to the last year of so. Sounds like a wonderful safety add-on.
Heard of them, never considered purchasing them. North Trail has a display set up for selling them that I have glanced at.
These (RettroBand) seem to be a different technology.
I'm plan to get the rettrobands on our way back north in the Spring. Earlier if they are installing them at the Tamps show.
What's the typical cost + installation?
Depending on tire size it’s in the range of 3,500 to 4,500 is what I got as a quote from NIRVC who is the only dealer for rettrobands. I am getting them installed when I go to LV. This vid shows the installation steps.
Edit: I had the wrong price points.
My only concern is making sure they don’t get damaged should the tire need to be replaced. I can see a tire tech unknowingly damage them if they don’t know how to work with the product.
I have the Tyron bands on my current gasser. Had them installed when I bought the coach. Never field tested them, gratefully, but it gives me peace of mind. I intend to have the Rettrobands installed by NIRVC when I get back from CPU...
It will be interesting if they can ever be bought after market and installed at a truck tire place. No way I'm paying that price point.
NIRVC has a no competition deal with the manufacturer. $4000 ish
I called what I thought was the manufacture but got the main call center for National Indoor RV Center (469.443.4764) and they quoted me $3,475.00, installed. This is for tire size 275/80R 22.5. And (according to this person) it makes no difference which NIRVC you go to, they will all charge the same.
I don't find that to be too bad for the kind of protection that they offer.
I guess it comes down to comfort with the safe handling of these coaches when the front tire blows. I have not had the experience yet (knock on wood), but from what I read and I think maybe @redbaron had described in a post long ago as a very abrupt lane departure in his situation. I wonder what the happens when the tire blows with the rettrobands installed, is it still an abrupt event possibly losing control of the coach in that split second, or is it something less severe that allows you to control the coach and get off the road safely. The cost benefit might be worth it if it means I can protect myself and others around me.
Watch the video on post 3 of this thread (10:35 mark). NIRVC conducted a test where they actually blew out a tire. From watching the video, there was no appreciable change in steering.
The difference between the two.....one keeps the tire from coming off the rim (Tyron) and the other basically gives you a secondary tire (internal rim/wheel) that gives you something to drive on, versus the rim. It would be kind of like a donut tire, but not rubber, inside the RV tire. I think both are VERY expensive, but the Retroband is the better system.
I assisted with the demonstrations of the Tyron bands when they were first brought to the US from Britain. They were introduced on the west coast and I provided the explosion (blasting cap inserted in the sidewall) that popped the tire during the press conference. My partner and I provided the explosives for the three demos on the west coast. They sold about 500 units to our Department, which installed them initially and then ended up tossing them in a pile. In law enforcement, the life of expectancy of a police car tire is only a year or less. They made it too hard to change out tires.
The Tyron bands worked by filling the center hole of the wheel, so the tire could not come off the rim.
Just keep in mind, these DO NOT prevent blowouts, they're job is to provide drivability after a blowout. Both units are really designed to allow you to continue to drive for awhile after a blowout. The Tyron bands were a big seller with the British military, an organization that may need to drive a distance on a flat, versus an RV that you stop quickly.
How about that!
