AbdRahim
- Dec 25, 2019
- BayStar 3626
- 37’
- Ford
- V10
- None
Weird size 76x 80 I think. However there is a largre overhang onbothe sides of the bed, maybe 18 inches or more on either side which is just a piece of plywood, unsupported on the outside edge. The bedding is heavey aklso, 2 1/2 inch faom topper and 2 in pillow topper cover.Do you have a standard King mattress or an RV size?
How thick is the plywood? If you replaced the mattress with a heavier one you may need to add support to the existing plywood or get a stronger piece. Keep in mind that wood grain direction will effect rigidity. A thin piece of plywood laid one way may flex, but rotate it 90 deg and there may be no or little flex.Weird size 76x 80 I think. However there is a largre overhang onbothe sides of the bed, maybe 18 inches or more on either side which is just a piece of plywood, unsupported on the outside edge. The bedding is heavey aklso, 2 1/2 inch faom topper and 2 in pillow topper cover.
yesDoes the plywood extend the full length/width of the mattress?
