Put awnings on an ignition cutoff circuit
Staff member
RVF Administrator
There should never be risk of an awning deploying with an engine running.
Ref:
It is my understanding that there IS an ignition cutoff with the Girard awnings. It just doesn’t ALWAYS work, apparently. We will be using the fool-resistant disconnect system from now on; pull the plug! It is now STEP 1 on the departure checklist.
I confirmed with Girard this morning that they provide an ignition interlock to Newmar with the awning. It is supposed to prevent what happened to us. I suggested that Girard might want to do some further testing of its interlock unit. He did mention that there have been cases where the interlock was not properly wired on some coaches. That will be on the check-list for resolving our issue.
When this issue can up a year or so ago, I deployed my awnings while parked and then started the engine. Sure enough the awnings retracted. There is definitely an interlock system in place.
Might be worth testing on your rig.
The engine was running on our coach throughout the unintended deployment. And, the awning was retracted while the engine was running, using the remote. Something ain’t right here!
but, if that simple test that @flyboy013 outlined doesn’t pass, you know you either Newmar didn’t install an interlock when they should have, or Newmar did not install it properly. In either case, Newmar’s negligence and that’s more points in your favor for a replacement.
It might also be worth a visit to Girard. I think that was how @CaptainGizmo discovered that Newmar was improperly installing them and we ended up getting a fix for that. If you were to visit Girard and they can show twisting, warping or other damage that would be consistent with a collision of that kind you described, that’s even more stuff in your corner.
I am pleased to report that Girard has stepped up and committed to replacing our awning, no “ifs, ands or buts.” We are now in the process of scheduling when and where this will take place and the ball is in our court. We’ll make a decision tomorrow, after we determine our availability schedule.
There was no defensiveness at all from Girard from the very start, they were wanting to get to the bottom of this and makes things right. I’m giving Girard top marks on this.
Where is the plug? I want to add this to my check list.
Mine is on ods side, forward of the peg bay compartment, opposite the oasis.
Glad that they are taking care of you @TJ&LadyDi. I wonder if it is actually a Newmar implementation issue since Girard is stepping up, or is it a known issue with Girard’s interlock.
Yep, driver-side bay just forward of the pegboard bay. On our coach, it is immediately inside the bay door, on the left just above the midpoint of the door opening. A white cord plugs into a standard receptacle located just inboard of the white controller box. See below.
Curious for those of you with Girards to do a test. Start your engine and see if you can run your awnings out or in.
Most of the luxury class A manufacturers use Girard awnings. Has the deployment issue happened with any of them, or is it only a Newmar issue?
I just tried it with mine. The awnings were deployed and the engine started right up. Using the remote, I ran the awnings in and out with the engine idling. I did not put it in gear...maybe that would make a difference. I’ll try that tomorrow.
