Answered Name that drip!
MapNerd
RVF 1K Club
Prince William, VA
Ventana 4326
2020 Ford F-150
Leaving the state park that I left my mark on, noticed a small stream coming out of the bottom of the RV.
It’s just water but I’ve never noticed it before. Makes me nervous. It’s coming from the center of that pan/cover thing under the RV, about midway of the second ODS bay. There’s no water inside the bays to be clear.
Anyone else have a drip like this when the engine is running? It’s not there when parked.
I dare say that's normal, I just had a discussion with @Chuggs about this as I had fluid under my coach leaving the last state park. I dabbled it with a paper towel and it was clear. He had a similar finding and was looking for the source. I'm sensitive to this after my shower pan drain leak I discovered last year. Charlie mentioned to me rain water can collect and drain out the bottom, mine was in the aft area, aft of the axles. At my next stop I inspected again after a shower and nothing so it appears it was rainwater in my case and not a leak within.
Have you had any rain or anything that could have collected and now you're seeing come out the pans on the bottom?
Try running the shower and other faucets and see if any flow resumes. Just monitor going forward if you can't make it occur as it again may just be rainwater collected in the pans per @Chuggs.
Just remember, you are changing the level when you get ready to move.
That makes sense. We did get several days of rain
There's a drain at the aft end of the front door side slide out. It drains all the water that was on top of the slide to the the underside of the coach. Here are some pictures of the drain tube on my coach.
Did you drive in rain, also??
At this point, I no longer recall but if I were to guess I’d say no as we try to avoid that.
If you have water dripping out those "drain holes," and/or your rear compartment floors or the bottom of your pegboard compartment is stained, you have water intrusion from road splash in your wheel wells. Hopefully, that is not your cause. Drain hoses for the coach are on the perimeter.
@C100 What’s the easiest, least invasive way to check?
Check to be sure your compartment floors are dry ahead of your drive wheels. Include behind the the plastic tray in your washbay compartment. I would take a garden hose and nozzle and spray against the bulkhead ahead of the drive wheels on both sides. I wouldn’t spare the water or the force of the spray. Check inside your compartment floors, ahead of your drive wheels.
Are you sure it is not coming from a joint on your exhaust pipe? Mine drips when the engine is first started.
Yeah I am sure that’s not where it comes from. it’s definitely coming from the center of that pan
I removed the "answered" prefix as it appears to be ongoing. Are you still seeing water at other camp sites / destinations?
I am not. Was just responding to recent posts.
