JoeHogan
- Nov 3, 2019
- Florida
- Dutch Star 4311
- Spartan
- Cummins
- 2018 Ford Flex
Living in Florida with the endless construction, the tradesman are sometimes sloppy with their supplies and deposit all manner of road hazards upon the roads. You say, how do I know this. Over the last seven or so years living full time in Florida I have had no less than seven flat tires. In my past, living in other states, I have put on hundreds of thousands of miles without a flat.
That said, my last flat, yesterday, was due to a roofing nail that had some flashing attached impaling my driver side front tire. It made a racket but was kind enough to let me get to the repair shop prior to leaking down.
Now the repair shop claims that the flat was unrepairable. It was not in the side wall but within the first couple of ribs of the tire near the edge. These tires had no more than 25k on them. Plenty of life left before the wear bars.
Had to purchase two new tires. I do not like having just one new tire on an axle so I replaced the flat tire as well as one that had been previously plugged from earlier this year (another bit of construction debris).
Is there some rule about plugging a nail hole that I am unaware of that makes the tire with a nail in it unrepairable? If the side wall is damaged, yes I understand that. But this did not seem to be that close to the sidewall.
This was at a local shop I have done business with since before moving to Florida full time. Maybe ten or more years.
Thoughts?
Thoughts?
