MapNerd
RVF 1K Club
- Nov 17, 2019
- Prince William, VA
- Ventana 4326
- 2020 Ford F-150
- Yes
After about a year of full timing, we started having issues with our water pump. Basically, the water pump’s positive 12v male spade terminal was compromised and if we hit just the right number of bumps in just the right way, we’d arrive at our destination and the pump wouldn’t turn on. We’d have to go and wiggle the wire connected to the terminal until we got the pump to turn on.
That worked for a few weeks but then one day while wiggling the wire, the water pump’s male spade snapped off. I sucked it up and went and bought another water pump.
Today, we came home from exploring and found that the water wasn’t working. Went to check the water pump and all seemed fine. Checked and replaced the fuse, made sure it was getting power and the right amount, checked the water tank level, adjusted the pressure switch…it just won’t start.
i can hear a very very faint crackling sound coming from it when I give it power. It sounds a bit like an AM radio trying to pick up a signal and it is very faint and this can only be heard when the pump gets power.
any ideas?
any ideas?
