Chuggs
- Nov 3, 2019
- Ventana 4037
- 40’
- Jeep JKU
Folks, if your terminal fitting are loose enough that "jiggling" makes them work. Maybe try crimping on new terminals spades. Use a bit of dielectric grease...give them a gentle squeeze after connecting.
When terminals are loose...they may spark a bit over the air gap. This oxidizes the connection. Oxides don't conduct so well.
Replacing the pump? If the terminals are the issue...the problem will follow.
