Frustrated with battery install
kangarooelaine
We just had some batteries and an inverter installed so we could do more with the motorhome. I asked my husband to handle the specifics and discuss things with the installer but we went together and talked about it all. Well, first off they didn't seem to understand what we wanted and so then we had to wait for parts and cancel a trip because of this. Well then it was all done and I thought it was great. Nope.
I knew batteries wouldn't be able to power the a/c or power it for very long but on our battery shakedown I tested that and ran the a/c for a while. The inverter started smoking! We could have started a fire. So that was the first problem: there's no breaker/fuse/trip. So now I have to monitor my usage in order to prevent a fire? I understand having to monitor my usage so I have battery life left for what I want or so I can use all the appliances I want but maybe at different times. But to monitor it to prevent a fire seems like too much. I feel like maybe the install is wrong.
They also didn't seem to care at all about how dirt and water might get to the batteries and inverter. The equipment isn't protected. I now feel like it's unsafe.
I just dont know what I should do. My husband understands electricity and I thought he'd be interested in this but he really doesn't seem to care at all. What should I do?
Take it back and explain what happened. Don’t think the inverter was designed to carry the load of the A/C. I could be wrong.
There should be a breaker on the inverter, as well as resettable breaker near the batteries.
I don’t know how old the rig is, but it sounds like the electrical system needs to be examined and repaired by a reputable repair entity.
rvservicereviews.com
From my limited knowledge 1 amp = 92 watts. Average A/C is 13 amps, = 1200 watts. Not including the startup surge load.
Rig is newish 2019. Was a rental before we bought it
Can’t bring it back yet. Not canceling another trip for this.
But also don’t want to take it back to an installer that didn’t install breakers etc. There’s a trust issue now.
Just a quick generic guide to power usage in an RV. BTW we have 600 amps of LiFEPO4 batteries and a 3000W inverter installed to run one A/C unit and residential refrigerator. Works fine for several hours. Also have 1400 watts of solar installed.
If you want to run A/C during the hot part of the day, this is a reasonable setup.
We need to know what model inverter and the size and qty of batteries you have.
A few pictures will tell a lot.
Also Wire size to the battery bank. I am not at all surprised that you have an install issue, when I look at some of the systems I fixed. Honestly I don't understand smoke coming from the inverter, more than likely from a bad connection or wire size issue.
2000w inverter
400 amp hour batteries
I wanted more but they complained about where to install it and said there wasn’t room. I think there’s room and they just didn’t want to figure it out. I’ve seen my rig in blog posts with set ups that are more powerful.
I’m not all that interested in being able to run a/c without the generator. But I do feel like if it can’t handle the a/c then it should have tripped a breaker, not started to smoke.
And now I’m discovering more issues. The batteries won’t charge. It was a constant issue on my last trip. I only had two days off hookups but since none of the batteries would charge I couldn’t even do very low power things like make my morning coffee. Had to pull out the Jackery.
As you have probably surmised already, your current setup appears to be inadequate for your electrical demand expectations. A coffee pot is not a low power appliance (see Joe's chart above). It's is, at times, difficult to find competent RV technicians. This is especially true when it comes to all the different wiring systems & components on a motor home.
I don't want to appear to be negative, but, I suspect there are a variety of issues at play.
Inverters will overheat if the wiring is inadequate or you exceed their capacity. That yours became so hot it started to smoke, should cause some concern. I would encourage you to have your entire 120 VAC electrical system checked out by a competent RV electrical technician.
1. how do I find a "competent RV electrical technician"? I'm so frustrated bc these guys charged so much and these batteries aren't even mounted to anything, only the inverter and 1 battery is mounted. They didn't design any custom rack to protect any of this. It looks nothing like any install I've seen on YouTube. We just trusted them because they seemed OK on a couple other jobs we had them do.
2. my husband had a BS in Electrical Engineering so he understands all this but simply doesn't think it's worth his time to do it himself or learn much about what's being done. (He does computer programming now and so it's not like he's really in that field of electrical engineering.) I felt like he could explain our requirements to the tech and he claims what we got should meet our needs. He says it's either manufacturer made bad product or installer screwed up - that the system should easily run any of our appliances and that if I overload it by doing multiple appliances at the same time it should trip a breaker. We are both confused as to why it even allowed the a/c to run at all. It really should have just tripped the breaker... which leads hubby to think it could be a bad inverter.
3. This is not a "your coffee pot takes too much power for your setup" situation. C'mon now. I can brew my keurig mini with my Jackery about 20 times! and this is supposed to be 4-5 times as much power. This isn't one little battery, this is four! with 100 amp hours each.
4. we were told it can't do a/c "yet" and that we'd have to install solar panels to get it to do a/c, WHICH DOESN'T MAKE ANY SENSE. (btw we aren't against solar panels, I just didn't want to add the height and weight to my rig just yet). Feels like they're just trying to get more money out of us.
This is not an easy process. We have spent years sorting through "technicians" to find a few that have very specific skills. Chassis work we go to A, Coach work we go to B, Electrical we go to C, non standard work we go to Z, etc. The hardest tech to source is someone capable of modifying an existing system successfully.
Modifications to any system takes a special kind of person and lots of time to understand the existing system (no matter how simple it appears). Just quickly throw a few parts at it, as you have discovered, is not going to have a satisfactory outcome.
You need to find someone familiar with your Brand and Model of RV, AND has performed this type of modification in the past. (granted this is obvious and not particularly helpful to you.)
Your best bet is to find a way to get your husband interested in completing this task. He is directly impacted by the outcome of the work (directly or indirectly) and will take the time necessary to understand what is required and complete the task correctly.
As you have figured out the most important part of a DC electrical system is the charging system. Honestly, solar is the best thing you can do, that said, the inverter has circuitry built in to shut it down long before it smokes. I know of no inverters that are not protected for 1.short circuit. 2. over voltage, 3. low voltage. 4.over temp.
You should have a breaker or fuse between battery and inverter, if not fix this!
Your inverter if it is a high frequency type and modified sine wave, will have trouble with heating element type devices, but should still work, but will be much slower, true sine is much better and worth the bucks. Also worth the money if you use the inverter much is a "Low frequency, low voltage inverter".
If modified sine wave you can have other problems:
1 devices that use electronics to change voltage to lower voltage, ie Triac devices, used in mouse control, chargers for things like electronics that don't use a transformer to do the job.
2. because of the lower power level of modified sine, heaters will not get as hot, this includes things like hot plates.
3. quite frequently GFI circuits, spike protectors, and such will get hot and use excessive energy from the battery bank, they may even go into flames.
Ideally It can be said using a generator to charge a battery bank is pound foolish. Solar float charges with out wear and tear on machinery. Batteries (not including Lithium tech) float charge the last 20% of the charge. Using a generator to do this is just wasting fuel. Used panels of the 250w size weigh about #60 about half that of a AGM or flooded 12v 105ah battery. Used panels sell for about 50 bucks for 250w. That makes 100 greenbacks for 500 watts of solar with about 1.5 the weight of one 105 ah lead weight. 500 watts of solar will make your coffee in the morning(not all day). ON THE RECORD! I don't feel anything less than 500 watts can be considered a system, and recommend whatever will fit on your real estate, Mine will hold 2500 watts and I have 2000w. I write this at 8:30AM and my batteries float at 29.5 volts (yes 24v system).
Now for why I posted on your thread. A qualified electrician can fix your 110 VAC system if you need help with it. If you are in Florida Solar installers must be certified. Mechanics that work on electric vehicles understand DC electronics. For the record golf cart techs understand 36v and 48v systems and controllers, this includes battery hook-ups. Contacting Solar companies for installers is a good way to find someone that understands how the complete system works. I am not talking about RV solar, I am talking about off grid cabin installers.
If you find installers that don't want to fix your system it is more likely that they only know one system, and can't help you anyhow. Just a point, don't be afraid to dig into your pockets to fix the system, if you find someone that tells you "No problem, we can get you set up", likely you will like his work.
Update: tech claims nothing is wrong with the system and tried selling us solar panels again.
As a refresher: my RV has less power now than it did with just the regular house batteries that came with it.
I had this installed:
2000w inverter
4x 100 amp hour batteries
It won’t run any appliances AT ALL. Tech tried to claim “running fridge 8 hours will drain batteries.” But I never even got one single hour of running the fridge with these batteries. Not one.
let me repeat:
my RV has less power now than it did with just the regular house batteries that came with it!
I can only do electric when plugged into shore power or turning on the on-board generator.
So now we need to find a new tech. My husband says his conversation with tech was beyond useless, clearly the tech doesn’t understand the problems. It’s obvious to me he barely tested anything out, just plugged it in and claims batteries are now fully charged.
No, I’m not using a generator to charge batteries. I’m plugging in at home or at RV parks to recharge the batteries.
The first thing I would check is voltage of each battery with a multimeter to ensure that the batteries are good and getting fully charged by the inverter.
Knowing which batteries (brand/model/type) you have installed would be helpful information.
After a full charge, let the batteries rest overnight with everything in the coach turned off and shore power disconnected, then measure the voltage of each battery. They should measure 12.7 volts. If not, then check the inverter charge settings to make sure they match the battery manufacturer‘s recommendations.
Optionally If you have a hydrometer, or want to pick one up, I would test the specific gravity of each cell. I do this on a regular basis with my batteries, but its likely an unnecessary complication at this point in your troubleshooting.
If you can report your findings of this initial test, then members can help with further troubleshooting.
One option would be to find a reputable mobile RV repair company to come out and work with you to understand the issue, test your system, and assist with ensuring that your 12 volt electrical system is working properly.
I'm surprised that no one has mentioned that one serious problem with your current setup is that it lacks the capability to supply the starting current needed to get the A/C compressor going. Yes, the compressor draws ~13 amps when running, but it has a "locked rotor" rating of probably more than 50A and an actual starting load of >30A.
A 2000 watt inverter is capable of providing starting current for the compressor in a residential fridge but not for an A/C. I have a 2.8 kW inverter in my MH and all I ask of it while we're on the road is to run the fridge, which it can do for ~8 hours on our 4-batter bank. My Samsung fridge requires ~11A at startup. I'll bet that the smoking was due to too much current being drawn through the inverter during compressor startup.
