Administrator
- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
I'm kind of confused. Did you have an additional inverter and additional batteries installed in addition to the ones you had before? So now you have 2 inverters and 2 battery banks? As my motorhome sits it has a 2000 watt inverter and 4x220ah 6 volt batteries in it, that's how it was designed from the factory.Update: tech claims nothing is wrong with the system and tried selling us solar panels again.
As a refresher: my RV has less power now than it did with just the regular house batteries that came with it.
I had this installed:
2000w inverter
4x 100 amp hour batteries
It won’t run any appliances AT ALL. Tech tried to claim “running fridge 8 hours will drain batteries.” But I never even got one single hour of running the fridge with these batteries. Not one.
let me repeat:
my RV has less power now than it did with just the regular house batteries that came with it!
I can only do electric when plugged into shore power or turning on the on-board generator.
So now we need to find a new tech. My husband says his conversation with tech was beyond useless, clearly the tech doesn’t understand the problems. It’s obvious to me he barely tested anything out, just plugged it in and claims batteries are now fully charged.
No, I’m not using a generator to charge batteries. I’m plugging in at home or at RV parks to recharge the batteries.
Can you post pictures of the install. Specifically the batteries, showing cables, and the inverter, showing a few angles and the cables.We need to know what model inverter and the size and qty of batteries you have.
A few pictures will tell a lot.
2- specific issue has nothing to do with a/c EXCEPT that if load on system is too high it should have breaker or something to stop it. I’m NOT expecting system to run a/c. I’m frustrated that when a/c was turned on, inverter started steaming instead of flipping a breaker.
This means you were plugged in? If so your inverter may have had 115ac back fed to the finals of the inverter. If so the inverter may well be toast. A transfer switch should be a part of the circuit.specific issue has nothing to do with a/c EXCEPT that if load on system is too high it should have breaker or something to stop it. I’m NOT expecting system to run a/c. I’m frustrated that when a/c was turned on, inverter started steaming instead of flipping a breaker
The voltage on your display will change depending on which phase of charging (Bulk, Absorb, Float) the inverter is in during the charging cycle. Even after charging they need to settle down for several hours before you can get an accurate reading. As I mentioned, it’s best to test the voltage with a multimeter at the battery terminals. If they test ok, then you know the inverter is properly charging the batteries.
Then you can begin a rundown test, watching the voltage with a load turned on to see how fast the voltage drops. With a 400 hour battery bank you should get approximately 10 hours out of a 20 amp load until the batteries are down to 12 volts which is typically the lowest you want to go before recharging.
As others have mentioned, it may not be with the batteries or charging system, but it’s good to rule it out before proceeding.
That's not how inverters are usually wired into an RV. In my MH my inverter has a 30A breaker in front of it and two subpanel breakers after it. Devices that I want the inverter to be able to power are fed through the subpanel. Other devices, such as the microwave, the air conditioners and the water heater all have their own breakers and aren't fed by the inverter. Your problem came about because the A/C was powered through the inverter which is not the standard practice.
As I stated, my advice assumed lead acid batteries, much of which does not apply to lithium batteries, so nevermind.No. My motorhome is a 2019 Minnie Winnie 22R. It came with 100 amp hour lead acid battery bank and no inverter.
We replaced those batteries with four 100 amp-hour Go Power Lithium Iron Phosphate Solar Batteries and added a 2000-watt Go Power IC Series inverter charger.
The motorhome has an on-board 4000-watt Onan generator. Originally the house batteries recharged en-route. The tech 'turned that off because it confused the inverter."
We will test soon. This is not a priority for hubby so I may need to cancel another one of my trips before it all gets done. So far it's 3 canceled trips because of this failed project and one trip we refused to cancel but was sub-optimal as a result.
This inverter appears to be designed to be sort of 'plug and play'. I don't think it's the same as how yours is set up.
Plugged in when? Not during that first shake down trip when the inverter started steaming.
After, yes. But batteries never seemed to hold a charge.
make sure your charge voltage is correct. the BMS will only charge the cells properly if the charge voltage is high enough.Plugged in when? Not during that first shake down trip when the inverter started steaming.
NOPE! Volts X Amps = Watts. Thus 13 amps X 120 volts = 1560 watts. That's running, not starting which could easily be 2X that amount.From my limited knowledge 1 amp = 92 watts. Average A/C is 13 amps, = 1200 watts. Not including the startup surge load.
