Under storage door handles/locks
Nickdorotik
I have a Jayco Precept 29. Almost all of the storage underneath is no longer usable as the handles are all jammed/frozen shut. Has anyone experienced this? Any idea how to rework this? Is there a replacement part that actually works?
lubricate them with Nut buster or something . Grime getting in them. I lube thru key hole as well i use either the key to push in a little or a toothpick. if that come out like that you probably could soak whole thing.
I have now broken both of the keys. Is it possible to order new keys anywhere?
i think that's the common key does it have code on it ? Should be 500
They suck. Keep them lubed up. My entrance door did the same thing. Friend told me to lube it up and I babied the key and that works. WD-40. I also had additional entrance key made. They take the number off the key, send that info in and I got a new key in about a week. Cost $13.00 tho.
