Hawkeye
- Nov 24, 2019
- Northeast Iowa
- Dynamax
- Isata 5 28SS
- Cummins
- ........2023 Ford F150 Tremor 2023 Ford Bronco.......
I don't think I can simply turn the Oasis burners on, correct? I don't want to turn the Oasis burner on for the hot water since I have drained the water out of the coach for the 20-degree projected temps tonight. I am hoping setting the thermostat to furnace for zones 1 & 2, I have engaged the Oasis System which will also heat the wet bay?
It does not matter if you drained the plumbing water out. The Oasis system is a closed loop, boiler type heater that heats the hot water furnace (with anti-freeze) and also is your instant, on demand, domestic hot water heater with no tank to winterize. Hope this helps, the Oasis is a great system, but very confusing if you have never had one.
