We do not know where it’s located.Have you checked the circuit breakers on the inverter/charger?
Call Newmar and ask. They should be able to point you to the location on your 2013 Canyon Star.We do not know where it’s located.
Inverter is working fine. Displays correctMost likely your inverter is in the second bay from the front. It is up between the frame rails. I have to go in on my back and take a flashlight. There is a reset button that you will need to feel for.
Newmar would not guide us as we are not “Newmar tech”. All weaeEDAxpCall Newmar and ask. They should be able to point you to the location on your 2013 Canyon Star.
Which inverter do you have MS2012? If neither the Generator nor the Shore power is providing a Charger current, there must be something interrupting that power. Look at the wiring schematic for that circuit for fuses and breakers. Is there a tripped breaker on the generator, or the fuse panels,? Did you indicate that you have Shore Power to the rest of the RV when plugged in?
Is the Battery Charger of the Inverter actually energized? How do you know?
These are questions that should be asked to a Tech that is familiar with RV electric circuits at this point.
Changing a bunch of parts without an understanding of the problem was an expensive method of diagnosing an issue.
This can be diagnosed with a test light and a schematic.
Please excuse the reference but is a good source of data
View attachment 8497Are You Missing Detailed Electric Drawings - iRV2 Forums
It's been noted that some are not happy with Newmars electric pfd's, plumbing, fusing & wiring details. Compared to when I arrived at Newmar forum its made a slow turn around that has producedwww.irv2.com
Newmar has only suggested that a “Newmar” tech could come and diagnose the problem at $145 hour…Call Newmar and ask. They should be able to point you to the location on your 2013 Canyon Star.
You said you didn’t know where the inverter is located and I suggested you ask Newmar to point you to the location. I certainly didn’t mean to imply that they would be able to fix the problem over the phone; only to suggest where to look for the inverter.Newmar has only suggested that a “Newmar” tech could come and diagnose the problem at $145 hour…
It would have been great if Newmar would have suggested where to even look for the chassis battery inverter but that info is not given out to an owner per Newmar. Only a Newmar technician. Both inverters have been found however they go to the tv and refrigerator NOT the chassis batteries so we are still on the hunt! An authorized tech did change the other relays and could not find the culprit.You said you didn’t know where the inverter is located and I suggested you ask Newmar to point you to the location. I certainly didn’t mean to imply that they would be able to fix the problem over the phone; only to suggest where to look for the inverter.
Obviously, you are going to need professional assistance with this problem and $145/hour is a pretty standard rate. You either need to have a qualified mobile tech come out or make arrangements to take your coach to a qualified service shop to have the work done. In either case, you should expect to pay the prevailing labor rate plus any parts charges.
