Rbjewell
- Apr 19, 2021
- Naples, Florida
- Airstream
- Pottery Barn Edition
- 28'
- N/A
- N/A
- 8,200 Lbs
Thanks, I already put a Safety+ and track bar system on it and it smooths out the sway and blowing around. I just want to smooth out the ride and not be so bouncy. Hopefully it will reduce the amount of stress on the interior when we go down bumpy highways.It depends on what kind of problem you are trying to resolve. Your BayStar is built on a Ford F53 chassis and many owners do chassis upgrades to improve handling. If you are just trying to smooth out a rough ride, good shocks can help with secondary bounce, but they won’t smooth out a rough road or do much for sway.
There are numerous suspension upgrades that many Ford-chassis owners have used to improve overall handling. Use the RVF search function for something like “F53 handling improvement” and you should find some discussion on the subject.
Koni shocks are good and are frequently used on motorhome suspension upgrades.
Sounds like adding the Koni FSD shocks as suggested by @Joe Goodxrvn might just do what you want.Thanks, I already put a Safety+ and track bar system on it and it smooths out the sway and blowing around. I just want to smooth out the ride and not be so bouncy. Hopefully it will reduce the amount of stress on the interior when we go down bumpy highways.
