Bluefire
Fish
RVF Expert
Marion IL and Moore Haven FL
Monaco Camelot
42PDQ
43 ft
Roadmaster RR10S
Cummins 400 ISL
2010 Ext. Cab Silverado 4x4
Please tell me about bluefire. I was thinking of getting it and an amazon fire tablet to use it, put the table to the left of the steering wheel.
I like the read outs on my aladdin screen but don't like having to look down and fumble to toggle between camera and readouts while driving. I figure this will cost me around $300+.
This stuff is getting expensive. I've almost been convinced to spend $200+ for 4 more txt sensors for my silverado toad, now I'm thinking I need this bluefire. I had pretty much everything I needed when I had the dually and montana.
Not all tablets are equal. Make sure the app works on the tablet before purchase.
I use Bluefire on Android tablets, Samsung and currently a Lenovo M10. I believe I've seen post about people using Fire tablets either on Bluefield Forums or the thread on the other website. I know there are other users here on RVForums. Happy to help, if I can.
Safe Travels.
If you haven't already found it, see this thread before you buy:
The fraudient adapters were also reported to be available on Amazon.
I think @redbaron did some development work on this. I may be wrong.
I have been using BlueFire for about 4 years. Originally I purchased to use as a diagnostic tool as I had an intermittent air pressure gauge FL said was fine. BlueFire reads from ECM which verified my issue was strictly an indication issue.
I find the electronic gauges hard to read quickly and really rely on BlueFire. I recently made sure I had fault recording active with all the DEF issues, BlueFire retains the codes even if momentary. I have been using iPad mini.
I was on amazon.com today buying battery disconnects since the one in my Monaco went bad. They had a few fire tablets for sale so I went to bluefire website to make sure for the last time that it would be compatible.
All portions of their website are down and have been for a few hours, this isn't an encouraging sign.
BF sites were up yesterday, I downloaded the latest adapter firmware.
Software bugs, servers crash, comm lines go down, power outages, backup generators fail, hurricanes, etc...Retirement Good,,,No longer my problem!
Safe travels,
I don't do apple but I did a search and I see that's around an 8 inch screen?
I've been debating on the amazon fire 8 and the 10.
$45 vs $75 on sale.
I'll find some mount to put it to the left of steering wheel and probably use it once we get parked for other things.
I wear 2.5 magnifiers to read.
@redbaron
Throw me a bone here, dawg.
I use it. I have an iPad mini and a galaxy tab so. Both function the same.
I use Bob Ged's screen layout that you can download.
My advice is to have at least a 10inch screen, and it should be dedicated to this role.
2x on @redbaron...10 inch and dedicated. I enjoyed building, and evolving my dash.
OK, stop twisting my arm, it hurts!
Ordered the fire 10 and 4 more tst cap sensors for my toad.
Will verify my plug in the morning and order the bluefire.
Bought 2 battery disconnects (one for a spare) a little while ago because I lost all 12 volt in the coach and it traced to the main battery disconnect.
This motorhome life seems to be more expensive than the 5th wheel life I was living before...
Hi all, just joining the tread.
Have had BF on my '15 Berkshire 40' DP (FL) for the past year to diagnose a problem, later to get better data. Used on both android and iPad . Great device/software.
Just taking delivery of a 2020 Newmar Mountain Aire 45' on FL chassis and looking to see if anyone has any interesting ancillary dash designs specific to MADP. Still working on where it will mount. Have a few ideas for a 1 DIN slide out but time will tell...
Great forum. Thanks!
Another great feature about BlueFire is fault recording and the ability to clear codes. Recently in testing a DEF simulator I got a 3131 code for low Def quantity and it was easy to clear the code using BlueFire
How did it work out for you using an Amazon tablet since you can't incorporate GPS with the app?
