I have owned many MoHo's over the years. Several Ford & Workhorse. I love going to the N. Georgia mountains. My Ford's did a lot of downshifting several gears to do mountain climbing. The GM 8.1 with the Allison tranny does much better. I also find the steering more like a diesel. Very little wander. I have the W22 with 22.5" tires.Im looking at 2004 Motorhomes to buy and want to hear some discussions on pro's and con's of a workhorse w22 chassis w/8.1 chev vs f53 ford w/v10 ?
Hello, it's September 2024 and I just came across and read your post, so being the owner of an almost brand new and mint 2003 Bounder on the Workhorse W22 8.1 Allison chassis that I purchased in May of 2023, I'm 100% intrigued by your Ignition wire and Irridium sparkplug post, so it sounds as if you benefitted from the parts change. I'm asking that if you would be so kind as to please advise me about what type/brand of ignition wires did you replace the OEM stuff with and also the brand and part number of the sparkplugs you replaced the OEMs with?Can't comment on the F53 Ford but I'll tell you I'm impressed with the Workhorse chassis and the 8.1L Vortec. I have done my share of crawling around and the frame is very well built. I recently replaced an ABS sensor and the connections and brackets were all still in great condition. Taking BRAZEL's advice I changed out my spark plug wires (solid core silicon) and plugs using Iridium gapped at .45. Very noticeable difference in added performance. Good for youo seeking advice. Continue to learn more about each and you'll come to "your" best decision.
www.workhorseparts.com
I'm going to get them both ASAP...thanks for the response brother...i truly appreciate it!..BRAZAL's Performance is an excellent source for Workhorse Chassis owners... The new spark plug wires made a significant difference in increased performance. As the wiring sits adjacent to HOT manifolds, these solid core wires are an improvement. Here's a link
SPW8100 - UltraPower 8.1L Magnum Spark Plug Wires
Part# SPW8100 - UltraPower 8.1L Magnum Workhorse Spark Plug Wires Description: UltraPower Magnum Spark Plug Wires are patent protected because of the unique method of producing these wires which have extremely low resistance while maintaining very high noise suppression. The benefit of thwww.workhorseparts.com
The Iridium Spark plugs can be purchased from various sources and are...
Spark Plugs: ACDELCO Iridium 41-101 gap set to .045 (stock is .060) BRAZEL's recommends the .045 gap. Worked for me![]()
THANK YOU FOR RESPONDING!...
