Russsilber90
- Aug 17, 2021
- Melbourne FL
- Dutch t
- 36ft
- CRV
Based on what I see here--I would be very nervous about it actually working.My safety cables attach to RV and run to tow bar holders attached to car. See pics.
Pulls 3000 lb CRV. No rust, lots of mud on road to storage. Clean up great. Use brake buddy with set up. Over 70,000 miles towing over entire country. Never gave it a second thought. Set up by authorized dealer to factory specs from Road Master.Based on what I see here--I would be very nervous about it actually working.
To clarify -- you only know that the setup is safe with it pulling the load that it is protecting.
I think the rust alone (if what I am seeing is rust) indicates that the material won't live up to its original design. Then knowing what rating was on the quick connects is another issue.
I know Roadmaster sells these. They are not one size fits all. Your weight determines them.
I have replaced all the safety cable and connectors with ones with stamped ratings, which means I had to forgo the quick connect on the jeep setup. My 2020 Jeep Wrangler is 6k lbs, and based on how a swinging vehicle could pull, all of the weight could end up on a single link.
I went with 12k lb saftey wire, and 12k lb connectors. These ratings are the stamped ratings and the working load, not the breaking point. The breaking point is what most will publish, and that number needs to be much greater (3x ) the actual working load.
If your Jeep is swinging, your supplemental braking system isn’t working.My 2020 Jeep Wrangler is 6k lbs, and based on how a swinging vehicle could pull, all of the weight could end up on a single link.
Oh, I agree--but I plan for failures at all levels.If your Jeep is swinging, your supplemental braking system isn’t working.
Your weight is very little. NO rust is good. I do not see a problem with your setup, and I am not suggesting that there is a problem with it.Pulls 3000 lb CRV. No rust, lots of mud on road to storage. Clean up great. Use brake buddy with set up. Over 70,000 miles towing over entire country. Never gave it a second thought. Set up by authorized dealer to factory specs from Road Master.
Sounds good. I respect your world. Having lived through 3 mechanical aircraft engine failures I put a lot of faith in fate. After all one blow out can ruin the best of all mechanical safety precautions.Your weight is very little. NO rust is good. I do not see a problem with your setup, and I am not suggesting that there is a problem with it.
Just be careful about the thought process of "x number of years, and never had a problem".
These things are only proven reliable once they do the job in which they are intended to do...meaning, once your road master fails and brake buddy doesn't engage---then you are testing your break away cables. Until then---its just theory.
I live in a theoretical world, as I have never tested my cables. So I have over compensated on the ratings to make sure that I have done all that is possible to ensure safety for the tow.
I have the same question. My current ones are coiled, and I need to replace them.I need new cables and am looking at the straight vs coiled versions. Question for youse guys who have the straight ones: Do you attach those to the tow bar in some way to prevent them from dragging? It seems they would tend to do that.
I have a Roadmaster tow bar that has channels on each side where straight cables run through the channels. Very clean, easy to store the cables and no chance of dragging.I need new cables and am looking at the straight vs coiled versions. Question for youse guys who have the straight ones: Do you attach those to the tow bar in some way to prevent them from dragging? It seems they would tend to do that.
I was looking for those all day yesterday and couldn’t find them anywhere. E trailer didn’t have them, blue ox didn’t…. If you have a link where they can be found, please let me know.The Quick Link I recommend is the Blue Ox 1/2" Quick Link for Safety Chains # BX229-0512 which is also zinc plated to prevent corrosion and have that 10,000 lb capacity.
