- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
I assume these are Newmar standard issue. I have a second GE one on order, now that I removed the couch to get to the second one.Any pics of your splitters?
Agree, a splitter with only the needed connections is ideal and then no terminators are needed either.Looks like the Newmar std 4 way splitter upper freq = 1000 Mhz. It will help if you go to a 2 way splitter assuming that is all you are using. A good 2 way will have about 1/2 the loss of a 4 way. Also I think it's been covered but putting terminators on any unused ports can also help.
No but my front tv remote turns on my rear TV when front is turn on at the right angle. Drives me nuts!! Is there a way to stop that?Anyone experience the rear TV not able to receive some of the cable channels present on the front TV?
Some channels come in but sketchy, only on rear (bedroom TV)
Anyone know where the splitter is in the Bay Stars?
Do you mean pointing straight at front tv?No but my front tv remote turns on my rear TV when front is turn on at the right angle. Drives me nuts!! Is there a way to stop that?
Is there a door you can close between the two?I can be sitting on my j lounge sofa in front of coach and turn on front TV. When I turn on the TV the signal from remote bounces off the front TV and turns on the rear TV on the opposite wall.
