- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
What's your technique for cleaning bugs off the windshield when you arrive (or before you depart) the campground?
I've seen various techniques, some take a lot more time than others. I figured I'd share what I do and I'm curious to learn what others do.
One option I got on my coach was a hot water spigot at the front of the coach which is in the GEN bay. This is designed for this very topic - bug removal. Yesterday I was covered with bugs, it was like wearing polarized sunglasses, a nice shade effect brought to you by your local bugs! I use diesel burner to ensure the hottest of hot water and also water pump on to make sure water pressure is not lacking. With this super hot water I can get 90% of the bugs off just by spraying. They seem to melt right off (disgusting). I then use my bugs-n-all and spray the windshield and lower half as well. I then use a bug scrubber with the squeegee on the opposite side and make a pass. Follow that up with hot water again and I'm done. Probably took me 5-10 minutes yesterday to get 100% clean. I used my water blade to squeegee all the water off, it's a little more effective than the smaller squeegee on the bug scrubber.
Amazon.com: Bugs N All 1 Gal. Concentrate Makes 32 Qts. Pre-Wash Vehicle Cleaner - Bug Splatter and Black Streak Remover. Includes an EMPTY 32 oz. Spray Bottle - Will Not Remove Wax! : Automotive
www.amazon.com
Amazon.com: Original Water Blade RV/Truck Bundle, 18 Inch Silicone T-Bar Squeegee with Pole Adapter : Automotive
Buy Original Water Blade RV/Truck Bundle, 18 Inch Silicone T-Bar Squeegee with Pole Adapter: Water Blades - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
Amazon.com: Mr. LongArm 3208 Pro-Pole Extension Pole 4-to-8 Foot: Home Improvement
www.amazon.com
