Flashflood
- Mar 2, 2022
Sorry def head , power glide chassis . We’re waiting for the part from tiffinCan you elaborate on “set head”? Typo? DEF head? If so is it on a Freightliner chassis? If it is you may be able to make it functional rather than replacing it. Pre-2016 FL DEF headers are a little more forgiving. Let me know...
Also what shop are you waiting on? And (if it is DEF and not SET) is it drivable with a MIL or derated? Got codes?
No they just say which number on their listGiven that its pre-2016 there still might be hope, especially if you aren’t derated. No word from Tiffin on a replacement time?
2ndjust curious - whats the number?
3216,3226,5746,4264.any ideasAre you derated or just have a MIL and codes? If so what codes?
Yes I’m sorry the code is 4364. We’re not sure we are not sure of the diagnostic they’ve done. They had an issue with their diagnostic machine diagnosing the codes I ended up giving them the codes from the dashboard and I’m assuming they use those codes to diagnose the problem.The first two refer specifically to the NOX sensor in the SCR, which is where DEF is converted to ammonia which then reacts with nitrogen oxide changing it to nitrogen and oxygen. Both codes have identical descriptions on my lists so as far as I can see they redundent. But these things happen. Commonly. There are far too many codes and some are repeats.
5746 is indicating a problem with the dosing unit or dosing unit relay. There’s a bunch of sub-codes to get specific, but essentially its saying the same thing as the first two - DEF isn't doing its job probably becuase it isn't getting to the SCR, at least in sufficient quantity.
4264 doesnt seem to exist but 4364 does. This fault code sets when the Aftertreatment Control Module (ACM) detects that the NOx conversion is lower than a calibrated threshold, which relates nicely to the first three. Could 4264 be a typo?
Anyway, my expericene, FWIW, is that this is most likely the DEF pump (or possibly just the DEF filter) and not the head. A bad pump will provide low or no DEF pressure to the doser and the emissions system, as complex as it is, sees this as LOW DEF and shows up as such on the dash. It can also stump technicians, and cause them to replace the DEF head unnecessarily, clear the codes, let you get down the road about 80 miles (in my experience) and then the codes come back and you are once again headed for derate.
Have they tried to diagnose it or are they just assuming you need a DEF head because you're getting a LOW DEF MIL with plenty of DEF in the tank?
If so they have you waiting for a DEF head you might not need and probably have the pump in stock. Can you elaborate on your experiences so far (any visits to a shop? indicators on the dash? derate status?), and also if its 4364, and not 4264?
Its possible that you need a DEF head, but you have none of the typical DEF head failure codes (level, quality, temp) and you do have codes indicating DEF isnt getting where its needed. The DEF head is primarily a monitoring device that reads conditions in the tank. It includes the supply line to the pump (and filter) but unless its plugged, its unlikely to be part of the problem.
Here’s a schematic of a typical system. In this chart, the pump is listed as “supply module” next to the DEF tank. The rest is pretty much self-explanatory.
1. I don’t believe it’s been diagnosed in a shop because they had a problem diagnosing it with their computer.So, to help firm up an opinion, please indicate the following:
1. Has it been diagnosed IN a shop?
2. Did a shop provide the codes or did you get them from your LBCU (or whatever its called on a Tiffin chassis)?
3. What other indicators do you see on the dash?
4. How far have you driven since this started?
A couple key points. Right now, according to your code list, you arent derated. To delay being derated as long as possible, do not start the rig unnecessarily, do not idle any more than necessary, and do not get fuel unless necessary and if you do try to limit to to less than 20 gallons. Once the ECM decides your emission system is malfunctioning, it counts ignition cycles, times idling, and tracks fuel usage to determine how soon you should be stranded on the side of the road to atone for your sins.
Here’s a couple charts to identify various MILs:
