Frustated in Havasu
1. I don’t believe it’s been diagnosed in a shop because they had a problem diagnosing it with their computer.
2. I got the codes off the dashboard.
3.Amber engine light came on pulling into town .
4. Less then 30 miles , driving back from the shop the red engine stop light came on .
Unfortunately we filled up when we got into town and the amber light was on.
I just edited my last post with this:
Ive spent some more time lookimg at SPN 5746 and specifically it indicates a faulty Dosing unit heater relay, or it could even just be a fuse, and according to one report, it caused a red stop engine light. I know you're probably not inclined to look at this yourself, but its worth a call to the shop. Its unfortunate the shop you went to couldn't properly diagnose before causing you this extended delay.
Here’s the post on 5746 - interesting reading. Also on a 2015. I want to learn from this one so let's keep in touch on it.
While 5746 indicates ”dosing unit heater relay” it appears that in a low voltage condition (Cummins sub-code 4156) it cuts power to the dosing unit and apparently that means the whole system including the pump, and not just the doesr itself. This would explain the other codes. It also still rather strongly indicates that it is not the DEF head, I’m still interested in what warning lights came on initially and what is on now, but its not worth cycling the ignition if you don't recall.
And here is a little more confirmation. Note that the dosing unit relay supplies power to the DEF heater (hence 5746), but it also supplies power to everything else in the system - pump and doser included, which explains 3216 and 3226. As I said before, these are all codes that I have never seen associated with a DEF header failure.
My coach has had two bad DEF heads and one bad DEF pump, and I’ve reviewed many other cases in my attempt to take control of these faulty emissions systems. So after delaying you for over a month, most likely for a part you don't need, I think a call to the shop is in order.
Is the Dosing unit in the head? Your help is so appreciated !
Sorry seeing the Dosing unit is not in the head
No but when they say dosing unit, they are including the pump which is mounted on the outside of the tank and the doser, mounted on the SCR, and apparently the tank heater which is in the head. However the heater has its own code - 5745, so the heater relay (5746) is much more likely to be the issue.
There are also two fault codes, 4155 and 4156 associated with SPN (suspect parameter number) 5746. They both lead to the same condition and repair, but they would need to actually perform the diagnostics to get those codes.
The relay that both fault codes refer to appears to provide power for all of it and of course it is external as well. It really requires proper diagnosis which I guess they plan to do (if they have diagnostic capability) after making you wait a couple months for the DEF head in case thats the problem. I imagine you wont be too thrilled if it isnt.
this is from page two of the attachment that the schematic in post 17 came from (I should have read it more carefully at the time):
“Action Taken When the Fault Code is Active:
• The ECM illuminates the amber CHECK ENGINE lamp and/or the malfunction indicator lamp (MIL) immediately when the diagnostic runs and fails.
• Diesel exhaust fluid injection into the aftertreatment system is disabled.
Engine torque will be reduced if the engine is operated for an extended period of time with this fault active.”
So this further explains your first two codes and increases the likelyhood that it is just this relay. The DEF head and dosing unit et al cant function under this condition.
I looked at half a dozen code lists before I found fault codes 4155 and 4156 associated with 5746. Most of my charts list SPNs but not the associated fault codes. My Cummins lists go by fault code but you have to dig to find the SPN because they are not in numerical order on the charts, and the dash diagnostics don't provide fault codes.
This is another reason they shouldn’t just grab an SPN and make a guess that can cause a customer to be stranded for months for a part that he might not need. I never wanted to make diesel emissions a hobby but my personal experiences (and experiences like yours) necessitated it. My goal is to never be stranded by my emissions system. Its also why Im interested in your case because every new situation adds to my tool box.
These are links for the faults codes for SPN 5746. Diagnostics should show one of them. I use OTR Diagnostics and it gives me all the codes, plus pages like these, so I am well armed when a dash light comes on:
2016 fleetwood pace arrow 38k 340hp isb. Was headed home and stopped to top off the diesel and def as we usually do because we live in the foothills. We were a couple of hours from home and about 1/2 way there i had a def light come on the display bar. I pulled over and scrolled to find the code. Looked up online to find that the code meant low def. After just topping off the tank. I got ahold of cummins and gave them the code and they told me not to worry about it. They said to keep on driving on home and that the warning light would go out, it did, and that the code would clear itself, and the code did clear. That was probably 4 years ago with no issues since!
Your correct! Thank you for all your help. We’re seeing a new mechanic next week.
Wow crazy
I logged on to Cummins QuickServe and ran SPN 5746 for both possible fault codes. This isnt new, different, or conflicting information, but it is from the horses mouth and these links should be helpful when talking to a service writer/manager. Hope this helps:
Cummins QuickServe links SPN 5746, fault codes 4155 and 4156
https://quickserve.cummins.com/qs3/pubsys2/xml/en/procedures/193/193-fc4156.html
https://quickserve.cummins.com/qs3/pubsys2/xml/en/procedures/193/193-fc4155.html
Thank you
These are my current fault codes on our tiffin, apparently not the def thank you Rich for your amazing help! Anyone else ever had these or know how to fix them?
So 3582 is the only active code. As it states, SCR efficiency is sub-par. That means it’s not getting sufficient DEF, which again points to either the pump or filter or both, with a less likely possibility that the doser is malfunctioning.
Unfortunately there is no sensor for the pump output (pump pressure), so when the pump goes bad it becomes a guessing game with the only clue being the resultant insufficient SCR effectiveness.
The good news is the test is uncharacteristically simple - a pressure gauge on the DEF output line - should be between 110 and 150 psi IIRC.
So 3582 is the only active code. As it states, SCR efficiency is sub-par. That means itw not getting sufficient DEF, which again poimts to either the pump or filter or both, with a less likely possibility that the doser is malfunctioning. Unfortunately there is no sensor for the pump output, so when the pump goes bad it becomes a guessing game with the only clue being the resultant insufficient SCR effectiveness.
The good news is the test is uncharacteristically simple - either a pressure gauge on the DEF output line - should be between 110 and 150 psi IIRC.
I owe you a Starbucks
