Refrigerator on battery
Russellvh
Forest River
Wildcat Fifth-wheel
2019 Ford F-250.
I’m sure there are endless variables but maybe just a general question. I just bought a 2022 Wildcat 5th wheel. Getting ready for first “shakedown” trip. If I go to the storage place the night before and turn on my refrigerator should it be able to run all night, to cool down, with out killing the batteries???
Electricity only. Top freezer and a little smaller than a residential.
Depends on the total battery capacity in Ah and the % of charge. I'd say 12 to 18 hrs with the refrig on battery would discharge the batteries. I wouldn't bet on it cooling and keeping it cool. You really need to have the trailer on shore power to be safe.
The fridge will tell you how much power it uses somewhere on a data plate. Use watts law and you can get pretty close on your calculations.
If the fridge uses 4 amps and it runs on regular 110 volt electricity. Watts law says it will use 440 watts. (amps x volts = watts). A fridge usually has a 50% to 60% run time...meaning it doesn't run all the time, only when it is cooling. BUT you are cooling down a warm fridge overnight? Figure a 100% runtime for that night to be safe.
What kind of batteries do you have and how many? Lithium or regular lead acid "car" batteries? Regular "car" batteries can only be drained to 50% capacity without damaging them. So if you have a 100 amp hour battery then you really only have 50 usable amp hours. Again watts law says 50 amps x 12 volts give you 600 watt hours. That means you could run a 600 watt appliance for one hour.
If your fridge is using 400 watts and it's running continuously, it will begin damaging your "car" battery in about 1.5 hours and completely kill it in less than 3. That is assuming the fridge is cooling 100% of the time. If you have two 100 amp hour batteries then you can double the time before your batteries die.
Of course all the numbers I used are made up. Replace my numbers with your own. This is an important lesson to learn in RVing. What can you run off your batteries and for how long. Good luck.
I am curious as to how you came up with 12-18 hours? Without knowing how many amps the fridge is using it would be hard to give an accurate number. But I am sure the fridge will be using around 4-5 amps. Since they are cooling it down from room temp the compressor will be running 100% of the time for at least 4-5 hours. 4 amps on 110 volts is 440 watts (460 watts if the voltage is 115v). Assuming the new trailer came with the crappy batteries most trailers come with, each battery is 75-100 amp hours. Lets be generous and say they have 200 amp hours and the batteries are fully charged. You can only use half of the amp hours in a lead acid battery without damaging them. So, they have 100 amp hours usable. That is about 1200 watt hours.
If that fridge compressor is running full bore trying to cool it down and using 440 watts... The batteries would be sustaining damage at about 2.7 hours. The batteries would be completely dead in under 5 hours.
Now, we would have to know the actual numbers from the fridge and the batteries. Not to mention the inverter has some parasitic draw as well.
I could be completely wrong. Maybe the start up amps on the compressor is 4 amps and the running amps is only 1-2 amps. That still would be cutting it close on cooling down a warm fridge. 🤷‍♂️
It probably won't kill the batteries, but it will definitely drain them down. Gas is better and more efficient and uses little propane.
The only issue is exactly what just happened to me, we went into storage under extenuating circumstances last fall! We never got back to remove batteries… We picked up RV and turned on shut off had plenty of juice for lights, on the way home I turned on fridge, it started fine green light all the way home, once we got home we figured it was good to go but about an hour or so later we noticed the fridge shut off. Turned out the batteries were drained and there wasn’t enough juice for the fridge to run! Even though it’s propane you still need to power it!
Saying one "drained the battery" depends on just how far it was drained. If it is allowed to go below 12 volts many times, one will need a new battery, regardless of how new or old it may be. Repeated discharge below 11.9 volts will shorten battery life. Anytime voltage, open terminal, and no-load, is less than 11.6 V this is the area of permanent damage.
Ok, obviously, I’m new to RV full time life. I will be spending most of my time with full hook ups but I might want to boondock sometime. Let me ask the question another way. I would like to know how long I can go unplugged from the truck and no outside (shore) power.
If I’m parked Can I just unplug and keep track of the time until the refrigerator stops? Or will that damage a battery or something?
You never want to let the battery get below 11.9 volts. Otherwise, you risk damage to the battery. Repeated discharge to less than 11.9 volts will cause shortened battery lift.
If you are concerned, I would visit it the day before and place some ice in it to cool it down first. A few one gallon milk jugs filled 80% and frozen. Then fire it up in the morning of departure.
2-3 hours max is all you will get. I have a 2021 Forrest River with the same problem. It's not really for boondocking unless you want to hook up a generator and I won't do that. If we boondock we just don't use the fridge and go back to coolers and ice. Good Luck!
I never thought of the frozen jugs of water but that is an excellent idea. When we purchased our first RV we immediately began full time traveling so there was never a need to prep or get it out of storage.
I'm guessing 4 gallon jugs of frozen water would cool the frig down overnight nicely.
