Newbie problem
bjdenise
Cedar Bluff, Alabama
Winnebago
Itasca Sunova
Workhorse
I had great water pressure throughout the RV and then all of a sudden I lost the water pressure in the kitchen sink any recommendations? I’ve already tried the aerator at the end of the faucet and also remove the nozzle to make sure it was not clogged.
  • IMG_8129.MOV
    16.8 MB
House filter clogged is the first thing to check. When is the last time it was replaced?
Is this the house filter? I don’t see one under the sink anywhere.
Hard to tell for sure, but it doesn't look like it to me. The picture you posted almost looks like the water pressure pump. Hard to tell for sure. Are you looking in the wet bay?
This one was located on top of the water pump on the passenger side, there was a large in-line water filter that connects to the city water on the driver side bay
Hard to tell for sure, but it doesn't look like it to me. Generally the whole house water filter will be in the wet bay. The picture you posted almost looks like the water pressure pump. Hard to tell for sure.
Yes water pressure pump, I assume this comes off?
Well, don't be taking the pressure pump off, that's probably not going to help you. Not unless the pump itself is dead.
Do you have water pressure anywhere in the coach?
This is what your are looking for.
The whole house water filter is the big thing on the right of the picture. The bottom unscrews and the filter in inside. Turn off the water from the water supply before you take it apart. Then turn the water on somewhere in the coach to take the pressure off the system.
In this picture, the sprayer on the left of the picture can be used to bleed off the pressure.
1631584605148-jpeg.8823
Yes water pressure everywhere else except for the kitchen sink, I was not going to remove the pump but remove the clear basket on the top and check that filter, maybe that will help? I don’t have a large filter on the exterior connected but will purchase one to connect to the city water line
As far as I can tell mine does not have this, it’s a 2005 Winnebago Itasca Sunova, there was a in-line standard water filter connected to the city water attachment and water pressure device
I'm pretty sure you have one, you may just not be looking in the right place. But let me ask, have you tried removing the water filter from the city water. Bypass it off and see if things get any better.
Yes I connected straight to the RV, great pressure everywhere except for the kitchen sink. Someone mentioned that may have air in the waterline but it seems like it would affect everywhere and not just one sink. I did remove the filter from the water pump it was nasty and cleaned it so in a few days when our freezing temperatures and I’ll put water back in it and test. Here’s a picture before and after of the filter that was on the water pump.
To be honest, I don't see it being pump related or it would be affecting all the faucets in the coach, not just the kitchen. For what it's worth, my Phaeton was the same way and we never got good water pressure at the sink.
I was about to change the faucet but ended up selling the coach so I never got to the bottom of the problem. But if you've changed the filters in the faucet, and everything else, then I'm afraid I'm out of ideas.
Maybe someone else can chime in?
