The saga continues.....
My friends called about 2 hours ago very happy as they were out of Freightliner and on their way from El Paso to Van Horne. I asked what the fix was and they said the Tech did a "forced regen"!
Well....about 15 minutes ago well on their way they called me and said ALL lights were back on! They have not derated and keeping their fingers crossed they can make it to Van Horne for the night and determine next steps tomorrow.
I had just finished reading your post Rich W when they called.
This is one of the problems we face. All regens, passive, active, and manual (aka parked or forced), happen in the DPF in an effort to burn off soot to keep the filter clear, active and manual occuring with the benefit of increased heat provided by injecting diesel into the exhaust.
DEF is injected in the SCR where urea, under high heat, converts to ammonia which in turn through a chemical reaction converts NOX (nitrogen oxide) into nitrogen and oxygen (air).
Thats all great (when it works) but it all happens AFTER the DPF and is completely unrelated to the soot filter which is cleaned by performing regens. But in my experience its the first thing a tech will do as a “rule out”.
Below is schematic of the sysstem: DOC, DPF, then SCR. So you can see that if you have a DEF problem, no efforts to change things in the DPF will address the issue.
Im sure the tech cleared the codes and reset the emissions sensing stuff, which got the owner out of the shop and down the road a ways, but did nothing to address the DEF issue, which is undoutably a faulty senssor, whether in need of cleaning or replacing. Once the sensors detected the problem for a long enough period, the codes came back.
Eventually he will be derated in three stages (see 2,3, and 4 in the second chart). He may not notice the first stage (25%) unless he’s towing and/or climbing grades. It would be interesting to see the codes he is getting on the LBCU. Reading the codes will also help him estimate how far he can drive before the final stage of derate restricting him to 5mph.
In the mean time he should not shut off the engine (limit ignition cycles as the ECM apparently counts them) or get fuel unless absolutely necessary, as these things accelerate the derate process.
Here’s a couple of other items to consider when you have DEF related codes and warning lights:
1 If check engine and the other s DEF lights are on and you fill your
fuel tank you will be you will be derated right away.
2 If you idle the engine for more then 1 hour with the same lights as above you will also be derated.
Ive also read that you can get fuel as long as you dont add more than 20 gallons. Some of this is from qualitifed sources, some is anecdotal, and some is probably guess work. But this is the only hope of delaying a full derate.
I would have turned around and headed back to El Paso (Im sure its too late now) since its 120 miles to Van Horn, and to my knowledge there are no resources there that can help. Eventually he will derate. I wouldn't drive any more than absolutely necessary as it is impossible to determine exactly when the final stafe of derate will occur.
