Crystalized DEF after setting 5 Months
bowpulpit
Monroe, GA
Ventana LE 4037
2011 Jeep Liberty
Have a friend who has been winterizing in Arizona for 5 months and left two days ago to head home to Mississippi. I spoke to him today and he is at Freightliner in El Paso because he got a "low def warning" and a check engine light on day one. Although his DEF tank was full, Freightliner told him the problem was DEF had crystalized in his tank after setting in the AZ heat for 5 months. Freightliner plans to empty his tank, check sensors ect which hopefully will fix the problem. In my friends case his tank was about 2/3 full for the 5 months he was here.
Ive never heard of this nor seen any posts regarding a problem of this nature so I'm concerned and curious. In my case I've here in AZ for 3 months (leaving for Ohio in 6 days) and wondering if I need to drain and refill my tank. I will say I topped my tank off the day I arrived in AZ so it's been setting full for 3 months.
With this post I'm asking if anyone has experienced this problem and had to drain and refilled their tank after setting for several months in a warm climate.
TIA
If you simply add DEF to the tank to top it off it should resolve the issue.
Thanks for the reply Neal. My friend did that (put in a jug-2.5 gallons) yesterday and the warning lights stayed on today from Deming to El Paso.
Possible DEF Head failure, low DEF warning is one of the indications.
The shelf life of DEF is approximately six months if kept in a cool, dark environment. Less if not. The result when not stored properly or when expired is crystallization.
While AZ can get cool and dark, it also gets really, really hot.
I don’t find this terribly surprising at all. Topping off the tank might help, but not so much if you’re topping off with a container that you picked up off the store shelf because who knows how long that’s been sitting on the shelf?
Best practice is to get DEF in bill from the pump as that has a high turnover and is constantly being cycled through, so you’re getting it as fresh as possible.
Just my ,02. Your mileage may vary.
I personally have had a major issue with getting DEF from the pump at a truck stop. The results of that actually resulted in me needing to towed to Freightliner. The result of this was contaminated DEF from the pump. They analyzed the contents of my tank and found it was contaminated with diesel fuel. I witnessed that as little as a eye dropper of diesel fuel will turn DEF into a milky substance . Result was a new DEF tank and also had to replace the DEF pump.
This very well could have been a one time freaky occurrence, but it was painful to us. I always look at the manufacture date on the Blue DEF before purchase to avoid the long shelf life product. Just passing on a horrible experience we incurred.
That does sound like a mind scarring experience
My question is was your friend stationary for the whole 5 months? I think the benefit of moving the coach every 4-6 weeks not only lubricates the engine but helps with DEF issues by circulating the fluid. I winter in South Florida and haven’t had an issue. Sorry to hear of your friends misfortune.
My son also got contaminated DEF at a truck stop pump. Found it had high volume of water in it. Another reason I deleted my truck.
So a couple quick notes:
1. There is a TSB on older (pre-2016) DEF level sensors and crystalized DEF so yes, a known problem. They can probably clean his DEF header and re-use it.
2. There are charts on DEF storage based on time and temp - best to familiarize yourself with that and deciphering the date code on containers.
3. Although the debate on bulk vs store bought DEF continues, you have control over what you buy with off-the-shelf DEF as you can examine the production date and view storage conditions. Bulk suffices for the vast majority, but Ive had problems withmit twice and will not use it in my coach.
4. Keeping the tank full will help, but after sitting for months, I would then drain the tank, flush with a several gallons of distilled water, and refill with new DEF before traveling, especially after sitting in Arizona.
This is the chart I use although my cut-off is one year old. Lately Ive seen some DEF with the date clearly marked, but some still use the ever-confusing year-minus one/reverse-juliian. This is important when trying to buy DEF less than one year old. A good strategy is to buy from higher volume dealers. I decode it by taking the year listed (first two numbers) and subtracting the Julian date (next three). The two letters preceding the date code denote the location of production.
I agree with these points…and I am concerned about experiencing these issues since we have not driven as much in the past two years, so I am not turning my DEF over as often. And I would like to drain my tank but there does not seem to be any easy way to do it (Freightliner) and there is no drain plug…
Any thoughts on a work around?
People that continue to just top off don't realize they are just aging their DEF fluid, I let mine get down to below half at least before I refill. If I've been sitting for a period of time such as now, I don't store full so I can add DEF to reliquify any crystalization. My hunch is the above has a clogged DPF filter or some other failure in the system and not related to DEF itself.
Or clogged DEF filter - forgot to mention that. Rigs that sit allow the DEF filter to dry out causing crystalized DEF to block it prematurely. Ive seen published maintenance intervals of 150k-300k miles but thats for trucks that run every day. RVs that sit for months need more frequent filter changes. Its an easy job and filters are around $45 for Bosch ($100+ if it says Cummins on the box, even though its the same Bosch filter). I do mine annually and carry a spare.
And unfortunately it could also be a failed DEF pump which will also trigger a “Low DEF” code, adding to the confusion. When my pump failed it was putting out about 5psi, when it should be around 115-150 (or shoot DEF across the shop if you dont have a gauge). And a plugged up filter can lead to early pump failure.
My rig came from Arizona where it only saw less than 3k miles/year of driving. So it sat in Arizona in the heat quite a bit before I bought it two years ago. The things you learn…. I’m hopeful that DEF pressure can be added to the list of data shown on live-data diagnostics in the near future.
As for draining, I simply siphon it out and carry a siphon hose. A hand pump from an old outboard can be handy for this (as well as changing your power steering fluid and filter). Its best to dispose of the old DEF properly, but it is essentially just liquid fertilizer.
Such great info from all that answered. Thank You
Freightliner took my friends Ventana LE into the shop about 2pm today.
Will post the outcome once I hear from them.
I purchased a Refractometer on Amazon today. Arrives sometime tomorrow.
Following you'all's advice I will test what's been in my tank these last 3 months and go from there.
More later.
Thanks Again
Fix for crystalized DEF - go camping more ;)
