- Jan 19, 2021
- Rosemary Farm
- Between RVs
- Toadless
I just edited my last post with this:1. I don’t believe it’s been diagnosed in a shop because they had a problem diagnosing it with their computer.
2. I got the codes off the dashboard.
3.Amber engine light came on pulling into town .
4. Less then 30 miles , driving back from the shop the red engine stop light came on .
Unfortunately we filled up when we got into town and the amber light was on.
Ive spent some more time lookimg at SPN 5746 and specifically it indicates a faulty Dosing unit heater relay, or it could even just be a fuse, and according to one report, it caused a red stop engine light. I know you're probably not inclined to look at this yourself, but its worth a call to the shop. Its unfortunate the shop you went to couldn't properly diagnose before causing you this extended delay.
Here’s the post on 5746 - interesting reading. Also on a 2015. I want to learn from this one so let's keep in touch on it.
DEF Error Codes
Hope this saves someone some pain and money... Had the following error codes from my ScanGauge D... ID: 1569 - Engine Protection Torque Derate FM: 15 - Data Valid but above normal operating range (least severe level) ID: 5246 - Aftertreatment SCR Operator Inducement Severity FM: 0 - Data...
While 5746 indicates ”dosing unit heater relay” it appears that in a low voltage condition (Cummins sub-code 4156) it cuts power to the dosing unit and apparently that means the whole system including the pump, and not just the doesr itself. This would explain the other codes. It also still rather strongly indicates that it is not the DEF head, I’m still interested in what warning lights came on initially and what is on now, but its not worth cycling the ignition if you don't recall.
