Tesla model Y. Installation of hitch anti-rattle clamp. It worked. 😊. For the archives. Pics included.
Voyageurs
RVF Expert
Howdy folks. Today’s project was to quiet down the noisy hitch receiver ball mount thingy. There is always some play in these things and every stoplight you can hear the clunk as it moves in the receiver. I wanted to use one of these.
But the Tesla wasn’t cooperating as the bolts impacted with the plastic at the bottom of the bumper hitch opening. So, headed back to Canadian tire and got this style.
Except without the lock as it would impact with the 7 pin connector. They are available with and without the lock. And the one without the lock is 20 bucks cheaper.
Really easy to put on although you’ll be on your back to do it. And you’ll need a 7/8 inch wrench. Tighten it down good and it will work well. No more noise. Here’s a shot of each side. Tight quarters but not a problem.
Only downside is you won’t be removing it fast as you need the wrench and a couple minutes. Worth it to us for the silence. And we tow our little RV a lot so we leave it on all the time anyway.
Sorry. The safety chain quick links are blocking the shot a bit.
And of course the obligatory shot of Jarvis our Tesla and T@Betha our T@B 400. 😊
Hopefully somebody finds this useful.
Voyaguers,
Good advice on the anti-rattle pin. I did go ahead and try the one you show that locks. Not so much worried about losing the ball mount but more the whole trailer. It fits with a little room to spare.
We’re also trying a greaseless Anderson ball. Figure as often as we’ll be unhooking this would be a plus trying to keep the grease off us.
Still wanting to get those those safety chain quick links a try you have on your Y. 👍🙂
Let me know how that greaseless ball goes. Trailer ball lubricant is icky.
Had a great trip. The ball worked out fine. It does show a little wear but I’m not overly concerned as it has a lifetime warranty. The anti rattle hitch pin did work itself loss once over our almost 6000 mile trip. Likely operator error. ;)
Have you had any issues with that anti-rattle device that goes inside the bar? You just feed it from the back? I have heard of those types of anti-rattle not holding up and becoming damaged and then must be cut off. I have used the traditional one like the max-haul you showed. I just tried mounting a stowaway2 on a tesla Y and found out the anti-rattle doesn't fit unless I cut into the plastic. I am looking for a good anti-rattle device so I don't have to cut the cover.
Hi Javi. No problems with our device, but heads up, we never remove the hitch as we tow a lot.
Hope that helps.
Happy camping season. We start again later this month.
Cheers.
Just thought I'd also chime in. The only issue I have had is it's worked it's way loose twice over about 10,000 miles of towing. But honestly I believe that was likely just user error. Both times I've just gotten my boxed end wrench out and put a little bit more effort into it the second time.
I have been taking my ball mount off between tows so that's were that 2nd instance had a chance to show up. I'll admit though I don't put the bumper hitch cover on and off each time. That's a pain in the.... 😄
Yep. Ours has never gone back on. 😜. And we have never removed the hitch ball mount either. 😊. It’s a permanent fixture.
