GFI outlets
James Mickle
I have a 2022 coachman leprechaun 319MB and there are a couple of outlets labeled GFCI but there is no GFI Breaker or and outlet with the test/rest buttons. My concern is that if it tripped by plugging something in i will not no were to rest it. Dose anybody know its at i been all over this RV.
Typically ONE has the test/reset buttons in the chain of outlets. You have to find the magic outlet.
What Neal said. It might be in the area behind the fridge accessed from the outside by removing the lower cover, or it might be in the bathroom, or an outside outlet. Once you find it, trip it and test the others and you’ll know you have it all figured out.
Sometimes there right on the panel and sometimes they are on a string. Did you check your outside plug or in the basement?
What does the vehicle owners manual say . . . . . . ?????
Rick
I am a electrician and no what should be but can not find any outlet with the trip/rest button and no gfi breaker in my converter panel. Even checked outlet buried in back of cabinet behind drawers. I crawled thru this RV from front to back and found not a thing. As far as owners manual it tells me ( you got it ) not a thing.
Thanks for all of the feed backs.
Is there a plug in the basement for an entertainment system?
If it’s 2022 you should be able to ask the dealer or factory. In my previous RVs they’ve always been in the bathroom. I’d look closer near water fixtures, behind entertainment systems where they could be hidden behind a tv and trace out where any factory supplied AC gizmos are plugged in. Outside outlets too
Double checked outlet in the outside entertainment is marked gfi but not the one i am looking for and outlet in basement is not the one either. No outlet in bathroom! Dose anybody have a contact to Coachman?
Thanks Again
Thanks Again
If I had a brand new unit, I’d ask the dealership who sold it. Consider getting out your gfi tester and make sure it trips while listening for the click. (It would probably a good idea to have as many pairs of ears helping out as you only get one chance!). If it doesn’t trip, perhaps they forgot to install it, and should be fixed under warranty. Quality control seems to be lacking in the RV industry.
To end this post i feel like a real dummy. Contacted the Coachman factory and it was in the bathroom Looked there many times and even said to my wife that there was no outlet in bathroom. But theres always a BUT there is one tucked in the millwork next to hopper same color as millwork. I would like to thank everyone for there reply’s. PS the factory sent me all of the shop drawlings. If anyone needs them for the 319MB leprechaun. Thanks again
Glad you found it.
