Tip Steps To Increase My Diesel MPG
FL-JOE
RVF 1K Club
Frostproof, Florida
Forest River (sold)
Salem FSX 270RTK-X
2022 Ford Expedition Timberline
I already mentioned in another post a camper here that transports new RVs out of norther Indiana. He has a few years under his belt and just "updated" his work truck because his old Ford was closing in on 600,000 miles and he was getting worried. His new truck is a 2019 F350 with only 98,000 miles. He considers it barely broke in.
The mpg he was getting towing and empty with his previous 6.7 Ford diesel was at least 2 to 3mpg more than I have ever gotten with either of my 6.7s. He has never done a DEF delete or installed any type of tuner on any of his trucks.
Last week he showed me what he has used for fuel additive for the last several years. I began using it (XDP Diesel Power Plus) and it has consistently increased my mpg by at least 1.5 mpg.
He also showed me his re-usable/washable air cleaner he uses. It is a K&N filter. It allows better air flow, still filters the same, and increases mpg another 1 to 1.5 mpg. I have used K&N air filters on my Harley's for several years and they deliver as promised. I just ordered one to fit my F350.
Averaging another 2.5 to 3.5mpg may not sound like a lot to some folks, but since we tow with our F350 plus use it for a daily driver our monthly average is around 2,000 miles. At todays current diesel prices this increase in mpg will save me around $100 a month, probably a little more.
I won't have the K&N filter on for another week or so. Once I have it installed and record 500 miles or so I'll update with the results.
Do they make a comparable product for "GAS" engines??
I changed my air filter before this trip (it had about 25k on it and was two years old) and Ive been using the economy “mode” shift strategy almost exclusively on this trip and will continue to do so except where it just isn’t tolerable.
Also traveling at 60 mph, much to the consternation of other travelers out there, although I do my best not to hold things up. My goal is to break into the 9 mpg range. We’ll see in a couple days. Crossing the Sierras didn’t help much but I have a lot of low elevation, more or less flat travels ahead.
I’m not sure about additives and also wonder about the cost of XDP and others per tank and how that affects the final cost per mile. I’ll do a little research on XDP. I doubt I’d see 1.5 mpg in this rig, but any improvement would help.
I read an article by an Allison engineer that said to always use economy mode.
That could be an objective opinion, based on a variety of criteria (I’d be interested to read the article), but in econo-mode it always hunts for the highest gear and shifts way too soon for most instances requiring acceleration. Basically the opposite of tow-haul in gassers and pick-ups.
So I find it almost excruciating. Maybe if I had more horse power it would be different, but with an ISB, this little rig needs all the help it can get, and since this is the same transmission used with the ISL powered coaches, its probably pretty much bullet proof in this thing. But Im experimenting with it because I’d like to see an increase in mpg.
Edit:
I think this a more objective discussion of econo-mode:
….but maybe thats just because its consistent with my findings.
Edit:
That's the article I was going to post, I think wolfe is an allison engineer. He posts on the monaco board. I've got the 400isl.
I guess I'm reading the article different than you as I read it as to use econ mode so it doesn't downshift so soon.
Yeah if I had an ISL I’d drive differently I’m sure. This thing almost wont move in econo-mode on even the slightest grade, much less from a stop. I find myself manually shifting much more often, and going in and out of econo-mode on grades, as the article points out might be necessary. I’m envious of the ISL, but if I can hit 9 mpg, it will help ease the pain. So I’ll stick with the program (no pun intended) for now and see what happens. If I get into the 9’s I’ll brag about it here ;^) .
We have an ISX, I always take it out of Econ mode for better acceleration (unless I forget, which doesn’t happen for more than a couple seconds). If we can consistently get into the 8’s, I will come back to brag here.
Will check out some of the other suggestions here to see if they can help.
When I had my 4369 Ventana I never tired the Economy mode. I guess my thinking was that my coach was always loaded plus I was always pulling a trailer with a vehicle and motorcycle. Of course I averaged 6.5mpg for the three years we had it also.
As far as the cost of additives. I believe Cummins (and I know Ford) suggests additives in the fuel for lubrication purposes. Also, most diesel additives give you additional cetane. Most of the bio-diesel we end up buying is 40-42 cetane. Our newer diesel engines like to get their best fuel economy on cetane ranges from 45-55.
For years (4 different diesel engines) I just used Diesel Kleen as my additive. It possibly increased my mpg slightly but I always figured it was lubricating my injectors. When you figure this XDP additive only required an ounce per 32 gallons it comes out about 1/5 the price of Diesel Kleen. So far I'm finding it is about 100 times better than Diesel Kleen for my application, so well worth the few pennies per gallon it is costing me.
Good info - I’ll look into additives. Thanks!
Be very cautious with K&N on diesel engines. It allows too much airflow, and can introduce dust that will pit the cylinders.
Pardon a dumb question but what is economy mode?
Its just a shift strategy that causes the trans to shift early and keep the engine at lower rpm to save fuel. It only has an effect during acceleration where it up-shifts earlier (too early) and on grades where it down- shifts later (too late). Its accessed by depressing the mode button on the top right of your shift panel. On the open road cruising in 6th, it makes no difference.
My plan was to use it almost exclusively on this trip to see if I could save some fuel, but I’m finding it almost totally useless, as pushing 32,000lbs with an ISB takes all the capability this thing can muster. Its almost not even functional in econo-mode when trying to accelerate or climbing a grade and as soon as you shift for it (which I find necessary) rather than wait for the program to get around to it, you‘ve defeated purpose. I typically shift earlier than the trans would in normal mode when starting up a grade.
