Michaelschmidt
- Jul 22, 2022
Thanks,I agreeMost tire failures are caused by (a) road hazards, (b) low tire pressure causing sidewall flex and overheating.
As to weighing the unit loaded, I find that from site to site and week to week our contents change, thus the load changes. Thus weighing the RV, I view, is not a practical situation.
If the tires are of the original type and size, I use the manufactures ratings found on the appropriate placard. Otherwise, inflate to the maximum cold pressure as found on the sidewall of the tires.
Bob
Thanks, this is good adviseUse the Thor recommended tire pressure on the label near your drivers seat (that PSI assumes you’re carrying the maximum weight) until you get the coach weighed, then adjust accordingly as mentioned in the above posts
