- Jan 19, 2021
- Rosemary Farm
- Between RVs
- Toadless
We checked that and they checked the capacitors. They think it was over-charged from the factory or a compressor defect. The replacement is in place and running exactly the way it should. But they also said this was the first new unit they have seen that has had this problem. Fortunately we were only 100 miles away and they could fit us in the next day so we didn’t have to go through a warranty hassle with an extended service appointment elsewhere.Could be loose wire or having compressor having hard time trying to start
It ran fine when it was installed but we only ran it for about 5 minutes to verify it was working and neither of us thought to check the amp draw of a new unit. It wasn’t until I was plugged in at a campground later that day and it started tripping the 20 amp breaker on that circuit that I realized there was a problem and identified the excessive amp draw (27 amps!).
Anyway we hussled back there the next morning (yesterday) and they fit us in between half a dozen other customers with appointments, and after testing and convincing Dometic it was a bad unit, replaced it with another new one that works just fine and we enjoyed it all afternoon and most of the night in a campground about 10 miles away.
Then we got hit by a severe thunderstorm (glad we weren’t driving) and with lightning flashing almost every second, I got paranoid and unplugged. The internet was really slow but I managed to get a look at radar and it was a very impressive red swath about 10 miles wide and 25 miles long (LaGrange to Elkhart) traveling north.
Today everything is soaked but the sun is shining in Shipshewana and after this and several other problems over the last 5700 miles, we finally feel like the vacation can resume.
If you ever have AC or refrigerator problems near Elkhart, this is the place to go:
National RV Refrigeration | Shipshewana, IN
National RV Refrigeration where we rebuild RV refrigerators and replace your factory fridge with a retro fit that will often out perform the factory unit.
