Resolved Autofill did not auto shutoff!
Came back from a long dog walk to find a pool under my coach and water gushing out the overflow and thankfully not bays, door, windows! Autofill display showed "Ready" and not filling yet it was obviously still filling. It did start a filling cycle before I left for the dog walk. Something didn't turn all the way off it appears. I turned off city water and it stopped. I then turned on manual fill, then off after turning on city water again, and also turned on autofill again and no flow. I'll definitely be watching this and carefully using autofill going forward. We've all heard stories and recommendations about turning off water when we leave which none of us do. But I think autofill may be a less "auto" process going forward. Turning it off when I'm not in the coach.
Anyone seen this? Just a sticking valve or what do you think happened?
Maybe the “full” sensor had a bad moment?
Has not happened to me….but I probably dont use it enough.
I bet the valve is stuck. Gunk from various water sources finally got it.
Was thinking the same and wondering how to clean it and wherever that critter is. May even be worthy of replacing. Hard water and whatever can't be good for it.
Anyone know the location of the autofill valve?
There appears to be an electrical device directly behind the water hose reel. Not sure if that's it.
That's it. I will post a picture
Autofill is stuck open. Not a big deal but will have to fill manually and turn off water. I can't figure out if there is a fuse related to this. I tried cycling salesman switch with no luck. I beat on it, no luck. I can reach in there, although a spider was protecting it, and nothing. I emailed Newmar parts yesterday to a part quote, guessing it's just dead and failed open. I guess better than the alternative.
If anyone knows if there is a related fuse for Autofill or any tips I can look into please let me know.
Found it in Newpar/Com_Net - part number 98606 for $262.50
8210G009MB-12DC
Perfect - thanks!
I emailed Newmar and they said it's not fused and it's likely dead. New valve comes Wednesday AM so I figured I'd take a break and have some "fun" and at least start some removal. I figured this would be "easy" as it looks like there are just two bolts holding the hose reel in. NO, there are two in the back! How did Newmar install these? With some power whining I got all four out. So then you'd think the reel would just slide out? NOOOO, it doesn't fit between the panel and floor rim. So I removed a few screws from the panel and it was able to flex enough. Studied the wires and cut them, removed the reel.
Waiting on parts and scuba gear, follow-up when part 2 is ready to share.
Why are certain things so hard to service? I remember reading someone saying they had replaced their oasis water pump 3-4 times recently. One time was enough for me to try to perform acrobatic maneuvers lying in the basement bay. I probably hit my head three times and took some skin off one or both of my hands. For those who remember TJ, he said to enjoy a nice adult beverage after. More like a 12-pack to get over the emotional and physical trauma I suffered. Just saying. Can't wait to see @Neal using his seal team rebreather with a wetsuit on putting the autofill back in.
Yeah, as I'm at end of trip T-minus one week remaining all I could think today was I'm selling the plane and RV and never leaving my house. I'm tired of fixing things. Joking of course but I'm blaming it on the recent birthday, seems like I jumped 10 years and I have the flexibility of an I-beam now!
You like to complicate things Neal. Every time I read your modifications, my head hurts. Never heard of KISS formula?
BTW, since you are already in there, maybe you should install a inline fuse. If the valve seizes internally, it will blow the fuse instead frying the electric driver.
Me thinks🤔
Well Neal, you'll have gone through all the systems in your Newmar by the end of your trips. Electifying some of the valves is handy until it doesn't work, so be prepared.
