Jireh Financial
Commercial Member
- Feb 25, 2021
- Michigan
- Holiday Rambler
- Vacationer 35K
Not how I do it, slides out then level. In my case there is a ton of weight going out (moment arms for the engineer types) that can easily throw off a level done with slides in.And NEVER open slides until you are level. Level first, then slides.
Ken
My Discovery said to level then deploy sides but my Newmar I have a warning letter from Newmar that states to check the gap on full wall slides then deploy slides and the last step is to level the coach. I always say to follow your manufacture's recommendation on deploying slides before or after leveling.And NEVER open slides until you are level. Level first, then slides.
Ken
OK, never mind. Apparently it matters.Is it actually a necessity to store a motor home level if all the systems are turned off anyway?
Certainly not but if you simply shut down & walk away some of the air bags will slowly leak until the coach settles on the frame. If you’re lucky and have a leak free air system then it will stay at ride height. It doesn’t really matter for storage purposes unless you want to operate the slides. In my case, with the coach parked in the backyard, my right front airs down in about 3 days. Sometimes I leave it that way for weeks with no problems and everything in the coach works just fine except the slides. If I want to operate the slides I start up the coach and let it return to ride height which is where Newmar recommends the coach to be for slide operation. Bottom line, IMHO, store it any way you want, just be careful with slide operation. And, I have a residential refer which doesn’t seem to matter being a bit out of level.Is it actually a necessity to store a motor home level if all the systems are turned off anyway?
Didn't your coach come with the Valid leveling system?In my case, with the coach parked in the backyard, my right front airs down in about 3 days. Sometimes I leave it that way for weeks with no problems and everything in the coach works just fine except the slides.
No, but I had Active Air installed by HWH several years ago. Sometimes I air level while in storage but since we go in and out of the coach a bit since it’s right at the house and there is some air bag leakage the small auxiliary compressor operates more than I like to keep the coach level. If the coach is going to sit for just 2 weeks or so I will air level. Otherwise I just let the coach do its thing.Didn't your coach come with the Valid leveling system?
Made a whole different coach, didn't it?No, but I had Active Air installed by HWH several years ago.
I am new to this RVing, my third trip out, I was on ground that was not level. I put wooden blocks under my back tires and Jack's. The back was much lower ground than the front. When retracting the jacks they all come up at the same time, I think. When I was retracting the jackets the rig moved forward about an inch, I bent one and broke one off completely. Keep in mind this was all my fault. I had taken the wooden blocks out from under the tires. By doing that the back tires are off the ground and now no emergency break!! I will never have my tires off the ground again. I have Lago blocks and will drive my rig on them along with Lago blocks up the Jack's.Hello, any advice on having the front tires off the ground after leveling? Is this ok?
