I’d say the circulation pump for the front zones (Heat Loop 1) is bad. Check the Oasis unit for a blown fuse. If yes, replace it and if it blows again, its the pump.
Sounds like you may be new to all the Oasis fun, and if so, go to that compartment, locate the stainless fuse block cover, identify any red LEDs, pull the cover off (no fasteners, just pops loose), and check the fuse that corresponds with the red LED. Likely Heat Loop 1.
If you do need a pump, you can either buy this one for around $90:
C1E Circulating Pump is part of our C series micro centrifugal pumps. It is a 12 volt 20 litre pump. It is designed to be quiet, compact and lightweight.
www.ussolarpumps.com
or the one from Hydronic Heating Warehouse for $345
ITR Brushless Pump 12 VDC 1/2 inch Connections Newmar Oasis Stir Pump 103705T The mounting for the new pump is 2 1/4 in diameter 2 1/4 Bracket for pump is sold separately If replacing an older pump. All three pumps are the same.https://hydronichea...
hydronicheatingwarehouse.com
Many have reported that the US Solar pump is a perfect fit and functions the same as the OE pump. It’s what I’ll use from now on.
