TXbound
- Jan 6, 2021
- Winnebago
- Adventurer
- Chevy P30
- 454 Vortac
- Yes
This morning about 8am without warning the furnace in our 1997 Adventurer started making a very loud noise with a vibration, I immediately turned it off, I suspect it's the blower or one of the exhaust motors. I've done some searching and found that on the Adventurer it's most likely a Suburban furnace and it's either accessible from outside or in the coach, one post said if has two screws where the exhaust comes outside of the coach than it's accessible on the inside, but if it has 4 screws it's on the outside, of course mine has 6 screws for the exhaust plates and that confused me, but I read that it's a panel that swings up, just like the rest of the storage and generator panels, so I looked below and sure enough there are 2 screws on both sides that are no doubt holding the panel, My guess is the panel should swing right up. I took out the 2 screws and it's swing up panel, it looks like both exhausts tubes connected to the exhaust plate need to come out, I'm in the process of doing that there is strong sealant I need to get at, I will edit as I go along. Got the black goo out of the way, had to use a heat gun to soften it up. I got the panel off and I can see the squirrel cage, I'm going to test it and see what I can observe, will report back when I see what's going on. Ok I tested it with the propane on, the noise sounds like our Onan 4000 so it's not enough to disturb the quiet, but after waiting for 3 mins no heat was observed so I turned it off I'm also concerned that using it the way it is may be potentially dangerous, so that's as far as I'm taking it I put in a call to a mobile repair and hopefully I will hear back from them. I'm taking the time to explain this in case others run into this setup. So now I have to look at the motors squirrel cages and see what the deal is the only times a blower has made a similar type sound or vibration was the chasis heater blower I replace it with a after market I found at the auto store and that solved, the other time was when the blower on the AC did something similar, my guess is this issue isn't solved that simply and the motor itself need replacement? I appreciate any help or advice with this as it's going to be in the 30's tonight and our electric heater doesn't cut it. Thanks
