- Nov 2, 2019
- Fulltiming
- London Aire 4551
- Yukon Denali
- Yes
My water pump stopped working last night and miraculously it is working today. Is this an indication of a slow death or could it be a result of other things? I've been having trouble with my black tank sensor and when it gets to 15%, it jumps to 100% and the red light goes off. In order to be able to flush the toilet, I've been taking the fuse out for the Monitor and Water Pump.
Last night, the temperature here in Montana was dropping to 32 degrees, so I disconnected my water and put the fuse back in so I could use my water pump to wash the dishes. It initially worked, but then the water started sputtering and then nothing. Completely dead. Today, I thought I'd just check to make sure the water pump was truly kaput. I put the fuse back in and voila, it works. The only other piece of information I have to add is that I had the Oasis burner on and was using hot water.
Any advice on how to proceed would be greatly appreciated.
Thanks,
Renee
Thanks,
Renee
