- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
Gassssssp, okay, no I didn't hit a bridge, well, yes I did. Heading from home (Richmond, VA) area on my way Gaffney, SC for my annual FL service (postponed from April 15th) on I-85 they had a few bridges that were interesting one as low as 13'10". GPS is setup, it's on I-85, all is good, I'm 12'10" according to Newmar, I think it's more like 13'2" but I have 13'5" in the GPS for a little margin. I have 2 (had) SureCall Omni antennas up front which are 9.25" tall (per my web search last night for replacements). One is attached to a mount on the roof, it's ABS designed for breakaway, one had broken months ago and I redesigned and attached to the front of a solar panel as it has a nice metal band around which makes things easy to attach to. Again, 3D print design with ABS for breakaway, well, it didn't make it to the CG with me. I had heard something twice while driving that caught my attention, I figured it might be thunder from the nearby storm. Nope. I noticed when walking the dog one of my white omni antennas was missing. On the roof I go (with a bad knee) and yep, nothing but wire left. Fortunately no damage to anything else, panels, AC, etc. Toad is fine, not sure where it ended up or if it disintegrated on impact. So yeah, the math is correct, I was right around 13'10" at the top of that antenna, bridge is validated
Fortunately I have too many antennas so I will likely just remove it's twin on the other side and no longer use that set that once was.
