Kevin D Pem
RVF 5K Club
- Jul 29, 2020
- AZ
- Alpinelite
- 26'
- 2016 Ram 1500
- Yes
I agree with @NealCan't see any reason to weigh with the tag axle up as it is load bearing and part of the equation for setting tire pressures.
Fascinating. I did not know that they charged by the number of axles with tires on the ground, vs total number of axles on the vehicle. I wonder how they calculate with all of the electronic tolling going on.The reason I ask came from a trucker on the I-35 turnpike. Seem that some truckers raise the tag/extra axles when loading allows to lower axles fees while on the turnpike. .
Guess you can find out, or not find out,, if you could benefit from the practice.
It seems like that threads general consensus was you pay the same, up or down.Guess what you do is up to you! I would weigh for per axle weight and see if my rig was legal per axle weight. If I was I would not pay extra.
For the record, I have nothing to gain, just passing on information. I don't/won't use toll roads! The argument that I can't visit some locations without them, just means I won't visit.
I don't have tags. I only remembered the conversation after one of you asked about a switch! As a disinterested party I only ask you don't feel above me,and discount what I bring up for your benefit.
Here is a forum discussing the topic:
Lift axles & toll roads
On what toll roads/bridges are we being charged less for traveling with the lift axle up ? i know I.L charged by the axle. so dose K.S P.A charge by the GVW. i looked online for N.Y but could not find it. what else ?www.expeditersonline.com
Thanks for that.It seems like that threads general consensus was you pay the same, up or down.
RV's that have lift axles are very different than trucks with lift axles. Many of the trucks lift the axle up high enough to actually see that they are lifted.
RVs on the other hand (except older country coaches) only release the air pressure. The tires are still in contact with the ground, just less weight on them. Its referred to as "tag dump" vs lifting now.
Older CC (possible other brands too) actually lifted them high enough to visibily see the difference.
