AbdRahim
- Dec 25, 2019
- BayStar 3626
- 37’
- Ford
- V10
- None
This is a test. Can you hear what I just said? Just checking to see if your hearing has gotten better!Anyone with the transfer switch under the bedroom, hear the transfer switch humming (in the bedroom) on a quiet night? I don’t remember it being so noticeable before.
Are you sure it's your transfer switch and not OASIS or whatever you have for hot water heating? Those pumps are continually spinning I believe. My OASIS hums, I know I have a pump that needs to be replaced solely on noise but as long as it continues to work I'm leaving it alone. Moral is, that's the source of my hummmmm (buzzzz)Anyone with the transfer switch under the bedroom, hear the transfer switch humming (in the bedroom) on a quiet night? I don’t remember it being so noticeable before.
No Oasis, but I have to listen when I get home. Am on the way home from Newmar. Parked in a quiet campground and heard this hum. Yes the transfer switch has a slight hum. However, when I unplugged this morning, I still heard the hum. I think it was my neighbor’s A/C.Are you sure it's your transfer switch and not OASIS or whatever you have for hot water heating? Those pumps are continually spinning I believe. My OASIS hums, I know I have a pump that needs to be replaced solely on noise but as long as it continues to work I'm leaving it alone. Moral is, that's the source of my hummmmm (buzzzz)
Thanks. Did not loosen first.It might be the time to cover the proper method to retorque a lug.
1. only use an inch pound torque wrench/screw driver.
2. one of the forces you must overcome is what is called sticktion. To alleviate this problem back the nut/bolt off before you torque to spec. More than one terminal/ device has been replaced because of the failure to follow this step.
Have fun and be safe!!!
