rocketman45
- May 31, 2023
I have searched the forum but have not seen this issue. Due to stop engine light had crankcase filter replaced. Thought all was fine til about 1000 miles later stop light on again.
Diesel mechanic has run code again and high crankcase pressure code again. Pressure is within good limit when filter is out but runs high when filter is in. No other codes, and no obvious mechanical symptoms... oil level ok, no smoke, no leaks, engine runs fine. Cummins 400 ISL. Anyone ever encounter this?
