city water
  1. AbdRahim
    Fresh water/ city water
    Those of you who have a valve that switches from city water to fresh water fill - do you turn off the water at the pole and depressurize the water system before switching from city water to fresh water fill and vice versa? I heard some suggest that operating this valve under pressure could...
  2. C
    City water problem
    When I hook up to city water, the city water passes into the fresh water tank filling it until it over flows. And yes. I have definitely closed the value in the compartment at the left side of the sliding door step. Because of this, I currently cannot use city water. Please advise.
  3. B
    Question Water tank fills when hooked to city water
    I’ve noticed my water holding tank is filling even though I’m hooked up to city water. Is there something wrong w/ my water pump? I’ve read I should shut the city water then run the pump to close a valve that gets stuck open. Is that the right approach?
