Hi all,
Quick question. Looking to see where folks get their air filter, fuel filters and oil filters (etc.) for your generator. I know you can go to Amazon and even Walmart (online), but often those parts are non Onan. Some say they don’t always fit right or you wonder about their...
So a while back my generator stopped cranking (model 10HDKCA-11506G). Whether trying from inside or outside it would never get to crank. It would, upon releasing start, blink three times meaning basically nothing helpful as it’s a more generic error code saying it needs further investigation...
A couple questions:
I have a Onan HGJAB 7k GAS generator. And I am going crazy trying to figure out what oil to use. I keep hearing of people using Rotella, but this is diesel oil and not SM, SN or SP, As conventional oil is getting harder and harder to find. What Type, Make and grade oil are...
So far we have only dry camped, as we are mostly involved in off road motorcycling. This past Thursday we left Phoenix with the generator running to power the house AC, ran fine.
Once camped out we had a hard time getting the generator to start, and once up and running it would eventually die...
Hello all, I am probably spending more time than I should troubleshooting my generator problem but i like to understand what is happening and why.
My generator (ONAN 4K KY) recently stopped working after running flawlessly.
I have narrowed down the problem for the most part but not exactly...
The ONAN/Cummins 4KY generator was challenging to start; if it did, it would not run for long. After reading all the threads here and elsewhere, this is what cured our problem - it may work for you.
I poured six 16-ounce cans of Sea Foam ($8.49 a can at Walmart) into the full 55-gallon gas tank...
