Can someone help me figure out what connection goes to which? I know the top two black connections are the outdoor shower and the left upper inlet is the winterize and the lower is the city water but where they connect to has me a little stumped. Very grateful for anyone who can help me.
I have a 2012 Lance 1575, single axle trailer, where the water pump (ShureFlo) runs continuously and I reduced water flow from my shower and faucets.
I borrowed a friends know good water pump and when I installed it the problem remained. I also replaced my on demand water heater with a 4 gallon...
My experience with water pumps (Shurflo 4008 series), is that they only last 3 - 5 years. I am curious as some of you don’t use city water.,and use the pump and fresh water. What has been your experience? How long do yours last, on average - especially those that us it a lot?
It would be...
Greetings from Pine Hollow Campground in southern Vermont!
Water pump not working. Green led lite doesn't come on when switched. Pump led on the controller illuminates when pump switch is pressed but goes off when switch is deactivated.
10 amp pump fuse is good.
Help is much appreciated...
I just posted a question about my fridge, and mentioned that I had a question about thte water pump as well. Here it is:
I had filled the water tank in my MH for a trip, and the next day I noticed a small puddle of water, and the tank had drained a bit. The water seemd to come from the tank...
New (to me) 1995 Southwind owner with a lot of repairs ahead. First order of business is replacing the leaking water pump and inlet filter. I've found replacement parts and they're on the way. Only (MAJOR) issue is that accessing the water pump seems impossible as it's blocked by a hefty outdoor...
Thor Motor Coach: F450 v10, 2017. Can someone tell me hours to access water pump? With switch on, I can hear it but there doesn’t seem to be any way to get to it. I think it’s located horizontally between the fresh water tank and shower. Refer to photos with red indications where I’m guessing...
Hello,
Super new motor home owner here. Recently bought a 1989 Fleetwood Southwind that was suppose to be good to go but actually didnt even make it home without issues, yes I was duped. We have been told that the water pump has gone and needs replacing. Unfortunately, no one seems to know how...
When I first got my 2017 Newmar Ventana I read that the flojet water pump wasn't that great and to put a variable speed pump in. I bought the recommended pump at Camping World and installed it. The water pump in my coach is just aft of the wet bay panel on the left side and is not the easiest to...
