13.5 A/C
We have a 13.5K BTU unit in our trailer. I use a 2500-watt Champion inverter generator powered on gas. I do have to switch it out of economy mode to run the AC and converter.
Do note that generators that are dual fuel are de-rated when run on LP. I've considered going to a 3 KW inverter generator but at nearly 100 lbs I deem that a bit much for this old man to lift in and out of the truck.
Bob
I agree Bob, I was worried about weight too, I found one by Genmax for $550 that was 3200 watt starting and 2800 watts running, and it only weighs 47 lbs :eek:. That was the lightest one I could find with that kind of wattage at the time and its a gas only generator.
Genmax 3200 watt Inverter Generator
