1998 Winnebago Brave 32 front end bushings replacement
turbineman
Most of the front end bushings on my 1998 Winnebago Brave are quite worn and loose, and need replacement.
I will most likely replace the shocks as well.
Most likely the back end also.
Is this work something a weekend mechanic can do?
What is good source for front end bushings and shocks?
Suggestions are welcome.
Thank you.
Give me your VIN and I will see if NAPA can supply them.
VIN No. 1GBLP37J6W311176.
Can the old bushings be removed from the various rods and linkages without a press?
Or, is it easier to get new rods and linkages with the new bushings installed?
Thank you.
