Question 2004 Fleetwood Pace Arrow main battery not charging from inverter
Newton36B
It did this once before and an rv tech replaced a fuse and all was good, I think he said it was the battery disconnect fuse, but I can't remember, in going over the fuse panel under the hood I can't find one for the disconnect. Anyone had this problem before ?
Perhaps an inline fuse by the inverter ? Also, Inverters have a reset button (somewhere on them) Look for one and reset...can't hurt to try there. Good luck...Blessings
Inverters don’t charge batteries so you might be going to the wrong area. Look for a converter, and if I remember correctly in that era Fleetwood quite often installed them under the fridge. It will be an intel power. It should have a couple 40 amp fuses on it. Check them out. (My memory is a little foggy on the location so you might have to hunt around a bit. Seems to me some of them had the converter in the bedroom too right above the power cabinet).
Good luck.
