2006 Outlook 31.5 ft generator question
C&KRome
Does anyone know how I would get the generator to run the AC and other electrics while driving? The generator works and it can be started from outside or a switch inside. However, the manuals (I have all of them) do not say anywhere how to use the generator to run appliances (AC, lights etc) while driving or even when stationary. Simply put the detailed manuals acknowledge the generator and all specifications, mechanicals, wiring and maintenance, but not how to use it.
Thank You
If you dont have a transfer switch, which is common on TT‘s and base model class C coaches, you have to connect your shore cord to power from the genny. Sometimes (usually, hopefully?) theres a 30 outlet for the genny in the same compartment with the shore cord.
If it is wired in, I would check the circuit breaker on the generator. On mine there are 2. They maybe tripped and not supplying power.
