2020 341RD Outback TT water pump and lines questions ?
roadking00
Looking for anyone that may have a detailed description of the connection points at the DC pump on this specific model? The camper had lines disconnected internally when purchased and just wanna verify what's what the best way possible and can't seem to find and schematics anywhere, alot of generic information but nothing specific.
The city water connection was cut at the connection point on the side of the trailer and in the process of repairing things after I get the new pump strainer delivered today, it had the cap and screen missing so could not test things yet.
Looks like the 2 way valve on the suction of the pump if lined up to the hose with no end on it is for antifreeze/winterizing and if lined up to the other port would be the fresh water tank suction ? My best guess ?
There's a blue pex that was kinked a d not hooked up, put a fitting on it and supply water through a hose and looks like that's the fresh water tank fill ?
The discharge of the pump has a T fitting which looks like is where the city water should be supplied to (at the T) when using city water to the trailer water system, correct ?
Have plenty of pics if that helps, I'll try posting them....
TIA for the help....
